I've been reading, searching for a few days on possibility of converting T3 FI motor to megasquirt. It almost looks too simple and makes me think I am probably missing something, hence this post...
I know there are quite a few folks here who is running MS with stock beetle injection hardware. Out of all conversions this seems like fairly straight process as most of the hardware is already in place. Fuel pump is there so are return lines and fpr. No messing with intake manifolds, throttle body and injectors. It's almost a PnP conversion except for a few hardware bits. And could look pretty close to stock except for a few giveaways such as wiring harness, IAC
Following sensors seem to require the biggest fabrication of the conversion:
1) O2 sensor (Bosch LSU4 ) http://wbo2.com/lsu/
Where to place o2 is where I have my doubts. Putting it in tail pipe is probably too far down stream, it won't get hot enough and can probably suck in fresh air. So far I've been thinking about putting into side of the muffler, but not sure if it will get enough flow.
2) IAT - GM Unit per MS manual
Thinking of placing in the bottom of the stock throttle body. There is not enough of room on the sides to have enough space for the hole and be able to screw it in.
I can mill off boss with two fittings and either drill and tap bottom directly on the body or attach aluminum adapter block with angle for the sensor so that connector points toward 3/4 side and down. This way sensor is hidden and I can isolate from heat soak using phenolic spacer.
Is there another sensor with 8mm thread that can be used in a stock location above 3/4 runners, or could I just use Bosch 0 280 130 014 ? http://www.carpartsdiscount.com/auto/pa ... 3593=52174
3) CLT - GM Unit per MS manual
In valve cover on 1/2 side.
hardware that doesn't really require modifications or fabrication.
4) IAC or Fast Idle Solenoid
Here I can simply use Bosch electric AAR (I actually have two of those and mounting bracket) Or just leave Stock mechanical AAR.
5) TPS Bosch 0 280 122 001 http://apps.bosch.com.au/motorsport/dow ... sition.pdf
This guy has almost the same profile as stock TVS and a "D" Drive type! The only problem I can see with it is connector receptacle being too close to #2 runner.
6) Ignition
Planing on locking out distributor and bosch 124 to fire coil http://www.megamanual.com/ms2/Bosch_124.htm
7) Injectors, will be using stock, but I want to find non D-Jet connectors, I haven't figured this one out. Is there a later part number that I can reference? Or can I simply use ev1?
Which leaves us with ECU, relay board and harness.
Given that I wouldn't even attempt to solder pcb boards myself, (I don't have steady hands, and really good eyes.
Could I just use microsquirt mounted in place of stock ecu? I could hide MAP sensor in gutted up bad MPS.
With MicroSquirt should I still get relay board? or will it be enough to drive stock injectors? If I do have to get a relay board maybe i can hide it in charcoal canister
MicroSquirt looks more appealing then Megasquirt as I don't have to hide it under back seat (little bit concerned being close to heater bellows. And it can sit where original ecu used to be.
I know this is a bit much of reading here, but I want to get a sanity check, since I always miss some important detail.
Thanks,
Anton
