Oil annalyzer
- Leatherneck
Oil annalyzer
So at work we got one of those portable engine oil analyzers. Anybody use one before? Any tips on using such as take a sample of the first oil out or use the last oil coming from the pan or should I use the filter oil?
Re: Oil annalyzer
I do a bit of sampling on heavy machinery and have been trained to take the sample from halfway in the sump, so a bit of tube down your dipstick tube should be enough. What does your analyser pick up? CAT do our analysis and report back with oil condition, particulates( materials) etc so you can establish a trend on bearing and component wear. Very handy to watch the copper levels etc for bearing wear.
- fusername
Re: Oil annalyzer
piledriver has his oil analyzed from time to time, but I think he mails out a quart for them to do htier magick to. maybe he gets special instruction from the lab that does it? I would ask him.
- Leatherneck
Re: Oil annalyzer
I haven't had a chance to use it yet but I will for sure be taking a sample from different points. Will hopefully get some time to sit down and read the manual, will pass on what I find out.
- Leatherneck
Re: Oil annalyzer
This is the annalizer that I have. http://www.reliabilitydirect.com/oilana ... -TMEH1.htm
So I tested it on my diesel engine with 24k miles on it and 4.5k on the oil. I used oil out of the filter, I will try other places later. When I tested it there is a scale of green - yellow - red. Mine was in the green at about 5/8 of the way, there was a number on it 37.3 but I don't know what it means yet still trying to find out about. The directions don't really give a lot of tech info. Again when I find out more I will let you know. If anybody runs across any info I would appreciate that too.
- fusername
Re: Oil annalyzer
if you want more info than you know what to deal with, I am sure Bob is the oil guy would have the answers. its a forum only for engine oil, so they would in thier hive mind most likely have used and or own that tool, and bgive you a better idea of what to do with it.
Re: Oil annalyzer
BUMP; what is the latest you found out on the oil???
Can we start to send in samples yet???
Mike
Mike
Jackpot motorsports
