Heads for my 2.1 litre OxyBoxer project
tmatre
Post by tmatre »
I am building an Oxyboxer for my 69 EarlyBay.
Mahle cylinders, Orignal WBX cam and lifters (new), Mexico EFI end-castings, generator stand and plenium. I think I need to modify the plenium and install a bigger TB for a 2.1 litre…
I will be using Megasquirt EFI trigged by VR sensor at the pulley
I think I will install an oil cooler in the doghouse and one additional temperature controlled oil cooler under the bus
What cylinder heads should I buy for this project?
I have looked at CB 044 Magnum with 40*35.5 valves
I’m not looking for a race engine, but more torque and stock look (That is why I do not use a Type 4 engine)
On Norwegian roads, typical cruising speed is about 2500-3000 rpm
