vanagon stroker
3literboy
vanagon stroker
Post by 3literboy »
I am faced with either just rebuilding a 91 vanagon trans for very little and then isntalling a stroker vanagon motor or having to build a performance trans for a suby conversion I:E: mainshaft, 4.13 ring and pinion etc.
I looked at the links etc. but
I was thinking 82 stroke crank, chevy journals, 5.352 Hbeam rods, 96mm pistons cut by .080 !
Who has th best price on pistons and HBeam rods with big pins?
I think I will just run 44idfs and a bug distributor since the injection is gone.
This should be 150 HORSE COMBO
The other scenario is offset grinding the 76mm core to 79 mm and calling it good with 5.352 Hbeam rods
naaaaah just 96mm pistons and the stock stroke and bearings
