He built/building a vert, yes one of those guys, you already know he is different just because of that. But he started with this.
And starts cutting
Working on his frame he built this. Ask him if he has a tubing bender. Answer that one for you, nope! Keep watching you will see lots of changes.
I like his one comment “ hope to be done by early spring” well he didn’t say what year.
He caught our attention with the start and the questions started to flow. And the mods begin.
Then talk of engine and games.Hedrock wrote:Well after much thought I decided that the distance between the "a" and "b" pillar posts was to close (too hard to get in and out of the car) so I took out the "a" pillars and the tube that holds the stearing bearings and the one above your head out for some slight adjustments. I moved the "a" pillers 2.5 inches closer to the dash. Doesn't sound like it would make much difference but it sure did. I figured all of this was easier than losing about 20 lbs.I'll post some pics when I actually get something done not just re-done.
Hedrock wrote:I have mostly been collecting parts to go coilover. Have all the parts for the front and will post pics of the "new" front end in a couple days.
One other part I came across was a 2180 engine. It is a good re-buildable engine and the best part was it was very afordable (free). I'll need to get a good set of cylinder heads and p/c and should be pretty much ready to go. Herbie might be right, I did play a little wack the penguin this week end
