Rattle can paint rack.........
- FireBuff
Just something I thought of to neatly store those damn spray paint cans that take up so much space on shelves and the one you want is always the one in the back.....solution: dishwasher basket...the cans fit like a glove ( get the basket that has alot of prongs, they can be bent if needed). I removed the top wheels to give the basket an angle,painted it black and secured it on the wall.....now the question is: where to get 'em......try the dumpsters at your local used appliance stores or anywhere else you can get one for cheap
I'm about as confused as a hungry baby in a topless bar !!!!!
- david58
Re: Rattle can paint rack.........
That is a great idea.
Well done.
If you can't find a dishwasher tray, I have another option, it is a little time consuming and probably a little more expensive. You could take a sheet of plywood, measure and drill it and glue in some dowel rods. basically the same thing but the advantage is you can make it as big or small as you need.
- Hedrock
Very clever idea
awesome im using this!
