type 1 84mm crank in oxyboxer help needed
tonicman
Post by tonicman »
i have a 84mm crank and wanna really use a wbx case how shall i do this and which case is ideal to use, or is it best to sell this crank and get another one more suited to the wbx block, am hoping to go mild tune and turbo/fuel injected cheers in advance
tonicman
Re: type 1 84mm crank in oxyboxer help needed
Post by tonicman »
and what are the limits of the wbx crank power and rpm wise if i keep a std 2.1 crank
ruffbiker
Post by ruffbiker »
Wbx cranks are among the strongest around. Power shouldn't be an isue.
Not sure about the rpm limit.
I'm gonna use it and plan on seeing 7000 regularly.
Rocky Jennings sells adapter bearing setups and T1 lifter adapter bushes, dig back in the forum a bit.
(Sorry, the STF search function still is borken, but Google site search works)
The std WBX crank uses the same 5x12mm bolt setup a T4 uses, and a T4 sized main at that location as well...
To ME, that would be the best reason to run a welded WBX crank vs. a Chinese wonder.
(Ideally, go all T4 mains, there are also adapter bearings for that... from some BMW IIRC)
pocketrocket
Post by pocketrocket »
I help about 2-3 month do a boxer conversion from water to air and also help many to do a boxer watercooled rebuild. If you would like to email me I can help you with the best block to start with and the main bearing you will need to do the t-1 crank into a boxer block. [email protected] web site www.rockyjennings.com Thanks Rocky
Jim Andritsakos
Post by Jim Andritsakos »
Thumbs up for Rocky :mrgreen:
AMBROSIA
Post by AMBROSIA »
^^^^ WHS :mrgreen:
