I recently had rear shoes and hoses (new springs in kit as well) installed due to left rear brakes not returning (broken spring as it turned out) and was heating up a bit. When I got the car back after this work, it seemed to stop fine. after a few days, however, the brake pedal started to return very slowly, (hydraulically or so it seemed..almost like a cassette tape deck door). This causes the brakes to stick for about five seconds or so when you let off of the pedal. When the mechanic looked at it again, he readjusted the rear brakes and bled the system, but the problem remained. He changed the master cylinder and bled the system again, but the problem is still there. He is stumped. Any ideas as to what might be the problem? Thanks for your help guys!
stumped on brakes
71woofybus
stumped on brakes
Hi people,
- david58
Re: stumped on brakes
The wheel cylinders are sticking.
71woofybus
the rear wheel cylinders were replaced as well, sorry for not mentioning. bad proportional valve? could this be in the brake booster? thanks for your thoughts.
busman78
Easy to test, take the booster line off at the engine, plug the vac fitting on the manifold and drive it, the brakes will work, just remember you will have to really push the pedal. If the pedal returns okay then you have your answer.
WestyPop
Possibly... bad flex hose(s), swollen or disintegrating internally, and not letting the fluid return quickly.
J.R.
SoCal
J.R.
SoCal
71woofybus
thanks for the ideas guys. really appreciate it. i've got someone who is helping with this next week who knows VWs real good, so i hope to let you know what the problem was and what fixed it! check with you later...
