Finished putting the buggy back together for the 2010 season
Re: Finished putting the buggy back together for the 2010 season
For paint, I always loved the black/red starburst pattern I once saw on a Lancia race car, I'll see if I can find a photo.
Works best on a car with angles... Provably be a pain with all those louvers tho.
Kinda like this, but it involved more straight lines.
The longer a vehicle rests on jackstands,the more likely it is to remain that way...
PhillipM
Post by PhillipM »
Yeah, similar colour scheme - we may go with some motocross style graphics/stickers something similar to that to break the chunks of colour up.
These days you could probably do something interesting along those lines with vinyl pretty easy and cheap.
PhillipM
Post by PhillipM »
Yep, even better, I have a vinyl cutter :D
PhillipM
Post by PhillipM »
Right, fixed the thumbnails on the previous page, should click through to full size now.
PhillipM
Post by PhillipM »
Next up we made some new output cups for the gearbox to the 930 CV's - the old ones were getting worn and rocking a little on the splines and the seals eventually start weeping because of the wear after a while.
CV's arrived...
...but instead of the GKN's we ordered - they were cheap EMPI things with fins machined under the bolthole and undersized balls - went back as they're not strong enough despite the insistance of the seller that they were better spec....;)
GKN's have been collected but they need a bit of finishing work and building up yet.
On with a bit more of the bodywork...wing time!
First up, back to the CAD (Cardboard Aided Design)
Then into plastic and foam:
And it started looking more like a wing:
The 3d printed ribs (big thanks to a fellow buggy enthusiast here with a 3d printer and a generous nature!) were finished for the front wing:
And that started to come together too:
PhillipM
Post by PhillipM »
And yes, I know the front wing is rather compromised by two great parachute-shaped mudguards either side, but they'll be changing, just not until we've got a few testing miles under her wheels.
PhillipM
Post by PhillipM »
Front wing skinned and foam filled in the leading edge for dent resistance, just needs the edges trimming ready for the sideplates fitting then it can be finished off:
PhillipM
Post by PhillipM »
Lost most of the pics from this but it's actually out and running after a lot of work and upgrades again:
https://youtu.be/RlC271i-JWg
