Lock Plates still needed?
mikemck
Post by mikemck »
the Beetle has a lot of lock plates to keep bolts or nuts from turning.
If we use lock nuts or Locktite are the lock plates really needed?
Re: Lock Plates still needed?
mikemck wrote:the Beetle has a lot of lock plates to keep bolts or nuts from turning.
That depends on which ones you are talking about. I did some remodeling on my new heater channels. The lock plates as you call them are flimsy sheet metal. I bought 3/8 weld in nuts from Fastenal for 24 cents a piece, they have them in metric sizes too. I am welding mine to 1 X 1/8th flat bar inside the channels. The weld in nuts or lock plates spread out the load.
mikemck
Post by mikemck »
Right now I am specifically interested in the locking plate at the end of the steering column shaft.
I plan to use a lock nut there and wonder if a lock plate is needed too.
Dangermouse
Post by Dangermouse »
<bump>
I'm interested to know this too, like the steering column bolt and bolts that attach the front beam - are M12 spring washers sufficient under the heads of these? I think the steering damper too?
But mostly the steering column attachment bolt scares me; I'd hate to have that one separate :shock:
