Blending Single Stage paint
hpw
Post by hpw »
Is there a how to or is it even possible :?: If there is can someone explain the necessary steps or provide a link?
http://s253.photobucket.com/albums/hh51 ... ?start=all
perrib
Re: Blending Single Stage paint
Post by perrib »
I use blending solvent to keep the edge wet. I use two guns.
hpw
Post by hpw »
perrib wrote:I use blending solvent to keep the edge wet. I use two guns.
Thanks for the reply, but I really don't understand what you are referring too. What does the "blending solvent" do :?:
perrib
Post by perrib »
Detailed instructions are on the can. You wet the edge of each coat of the blend. You can do the same with a little of the color over reduced but the blending solvent works better.
craigvwdude
Post by craigvwdude »
You can also use a slow reducer for blending. That's how they did it back in the day! :mrgreen:
When you've brought your color out into the middle of a panel for blending, dump the paint out of your gun and poor strait slow reducer into the gun, then go over the "blended" area with 1 or 2 LIGHT coats of pure reducer. The reducer will help the paint "melt" or "blend" in. Wait a day and hit the blend area with a buffer and some compound.
Should come out oh soo nice and purrty! 8)
