74 Ghia rear trailing arm removal
- kpghia
Some shots of the removal
...and replacementYou do not have the required permissions to view the files attached to this post.
- kpghia
Re: 74 Ghia rear trailing arm removal
Removed the arms, installed boxed trailing arms, 1.5" narrower.
- kpghia
Stub axle installed. Trailing arms bolted into place very nicely.
- kpghia
Of course narrowing the rear requires shorter axles. From asking around, type 3 automatic axles are shorter on the drivers side and the exact length for this project...just not readily available. Sooo, I bought some used SAW axles and cut them down myself.
Thanks for posting that KP, and Sweet Ghia !
