how to install oil squiters ?
Flagbuggy
Post by Flagbuggy »
topic says it all :D
2.4 Type 4 Turbo Flag buggy 11.1 sec
13BT 240KW Cabriolet Bug
66 Freurwagon Long term project
66 Squareback Sunroof Project
2000 NB VR6 Turbo Project
84 DC 1.9WBX
86 Kombi 2.1 WBX
WBX Man
Re: how to install oil squiters ?
Post by WBX Man »
Flagbuggy wrote:topic says it all :D
Does it !?
Oil squiters where to ? Piston, rods, cam lobes, or ???
Most folk are referring to piston oil sqirters.
There are some great older threads covering this, try this in Google: (If the STF search lets you down)
oil squirter install site:shoptalkforums.com
You probably want to read this thread:
http://www.shoptalkforums.com/viewtopic ... sc&start=0
Flagbuggy
Post by Flagbuggy »
:oops: WBX MaN OK YOU got me :D
Thanks Piledriver thats what the doctor orderd
84 DC 1.9WBX
86 Kombi 2.1 WBX
buildabiggerboxer
spray jets
Post by buildabiggerboxer »
guys , just a little input, there are of course much cheaper options than expensive porsche items.
but back then i never new these even exsisted when i did my first set. ive used screw in carb jets, weber idle jets, and best of all plain drillings, nothing to foul up or go wrong!. the check valve in the porsche part may or may not be advantageous on a road car, but ive never had over oiling or preasure issues, but then ive never had a piston failure , the con rod method is used on hirth cranks, but for a different purpose ,and seems an effective method.
I prefer the elegant simplicity of the side notched rod BE, the pressure-relief type squirters have a bad reputation for sticking open.
Putting a hole in the bearing/rod in the right place works well, for example, the Toyota 2JZ six used that method.
OTOH, that is also a common failure location of the 2JZ rods, but not at remotely stock power levels. (which are far higher than most will ever see from an ACVW at any modification level)
Flagbuggy
Post by Flagbuggy »
Piledriver wrote:I prefer the elegant simplicity of the side notched rod BE, the pressure-relief type squirters have a bad reputation for sticking open.
Putting a hole in the bearing/rod in the right place works well,)
You got any pic tures :D
84 DC 1.9WBX
86 Kombi 2.1 WBX
