Fuel system for Wasser
knox
Post by knox »
Found a 2.1 wasser today for $250. I will pick it up next week and start the rebuild. My guestion is would i be better off trying to transfer the fuel injection into my 71 Bay or just try to find or build intakes for a dual carb setup?
If i can transfer the fuel injection how big of a pain is this going to be?
Or does anyone make dual carb intakes for a Wasser?
What kind of upgrades can i do to this motor to get more power? I've heard exhaust, 1.4 rockers and the chip will help. But what power will these bolt ons really give me?
Knox
fastback
Post by fastback »
Type 1 manifolds bolts onto the WBX head , but some need adding material as the WBX ports are big
or u can buy these:
http://www.csp-shop.de/cgi-bin/shop2/sh ... 7354a&pn=0
knox
Post by knox »
I am going to try to reuse the 2.1 injection since looking at the vanagon the harness it is straight forward and just seems to need a power and ground either at the junction box or brain? Am i correct?
I would think that the injection would give smoother operation and efficency over the rpm range verses dual carbs.
Is there the ability to possibly use the factory injection for a turbo application later down the road or would the fitment of a later injection setup be better when i come to that bridge?
Might go with Megasquirt as i have a friend in Charlette who is upposed to be a whiz with that stuff.
Knox
fastback
Post by fastback »
the europe version is as u say only :
+12V
ignition "on"
ground
1 wire to the starter solenoid
2 wires to the fuelpump
and u are rady to fire
