An good fuel filter for single outlet tanks
Posted: Sun Feb 22, 2009 2:22 pm
This is the filter that goes on my 2006 Jetta. http://www.yiparts.com/Part/en/PBXWS
It has two inlets and one outlet. It also is good to 4 bar in pressure. I am not 100% sure if it is internally regulated. It would be a perfect out of tank filter for injected cars with only one tank outlet. The return line would go to the outer outlet of the two on the end. Its right at 2" in diameter and about 4" long. The outlet end is teh single nipple end. Its Mann # is WK 69/2. Its about $35....but is all metal.
The new one is welded/sealed. The original one on the Jetta though....appears to have a pin/clip holding an element into it. I will take pictures of both...and disect the old one when I get it out. This would alleviate needing teh "Y" for the return line on D-jet, L-jet and others when going into a stock non-fuel injected bug. Ray
