No. They are not even of the same layout. On a beetle, the hubs are cast with splines cast/machined in. On a 411/412, you have a forged stub that bolts to the drum. That Stub has a set of splines on the inboard end that then made to a female splined hub that bolts to the CV joint.
There are no other VW's that use either this set-up of the rear bearings...although the type 3 uses the same cast hub. Ray
i was just wondering as i have a set of porsche disk brakes of a rear of a 944 turbo witch just bolts on to a swing axle or irs bug. and wonderd if they would fit the 412 if the splines was the same
