Engine Related Fasteners
Please add quanity, thread sizes, thread pitch, length, and tools needed.
Connecting rod cap screw - 32 ft-lb - m 9×1
Connecting rod nut - 24 ft-lb - m 9×1
Crankcase nuts m 8 - 14 ft-lb - m 8
Crankcase nuts m 12 - 25 ft-lb - m 12×1.5
Crankshaft pulley - 94-108 ft-lb - m 20×1.5- m 9×1
Cylinder head nut 10mm - 23 ft-lb - m 10
Cylinder head nut 8mm - 18 ft-lb - m 8
Engine Mounting nuts - 22 ft-lb - m 10
Fan Mounting nut - 43 ft-lb - m 12×1.5
Flywheel Gland nut - 235 ft-lb - m 28×1.5
Generator pulley nut - 43 ft-lb - m 12×1.5
Heat Exchanger at head - 14 ft-lb - m 8
Intake manifold nut - 14 ft-lb - m 8
Muffler Clamp bolts - 7 ft-lb - m 6
Oil cooler nuts - 5 ft-lb - m 6
Oil Drain plug - 25 ft-lb - m 14×1.5
Oil filler gland nut - 40 ft-lb
Oil Pump nut m 6 - 9 ft-lb -
Oil Pump nut m 8 - 14 ft-lb - m 8
Oil Pump nuts m 6 - 9 ft-lb - m 6
Oil Strainer nuts - 5 ft-lb - m 6
Preheat-flange bolt - 7 ft-lb - m 6
Pressure Plate bolts - 18 ft-lb - m 8×1.5
Rocker shaft nut - 18 ft-lb - m 8
type 4 rocker nuts are M7 w/ an 11 head
Spark plugs - 25 ft-lb - m 14×1.25
Thermostat Stud M8 x 1.25
Oil Sending unit Thread Size M10x1.0[/b]
Engine Related Fastener Sizes and Tools to Use
- david58
