Clutches
Different styles of Pressure Plate and Throwout Bearings Type 1
Which clutch
Replacing Release Shaft
Which Clutch Cable
Clutches
- david58
Re: Clutches
I need a little help her guys answering this question.............SUBLEVEL88 wrote:like the post about the clutches im putting a 65 engine in a 73 bug so all i have to do is take the centering ring out and it will work or do i need to get a new clutch and pressure plate and will that clutch and plate bolt up to my 65 flywheel
- Glenn
Re: Clutches
The 73 tranny is a SSC (Single Side cover) and uses the late model throwout bearing and has the larger cross shaft. you you can not switch to the early style TO.
So you have to remove the centering ring for it to work.
SUBLEVEL88
Re: Clutches
going to give it a try with the centering ring tomorrow will be back on tomorrow night to let everyone know how it goes
SUBLEVEL88
Re: Clutches
well that worked not sure if my three finger 6v flywheel is going to hold up, thank u guy u really dont know how much u helped me just pray that everything says together if this i can get this engine to run ill buy a new pressure plate lolU GUYS ARE THE GREATEST
- david58
Re: Clutches
I had a pressure plate that had a center ring that was not removable. I called Denny at Savannah clutch and the one that he had in stock had a centering ring and it was not removable either. Hedrock sent me a ring to get me going. I had a new pressure plate that needed the centering ring.Glenn wrote:
SUBLEVEL88
Re: Clutches
the only thing im worried about is my pressure plate is a three finger instead of a multi finger but the center ring came out with no problem and lined right up hoping that the three finger doesnt mess up the TO bearing. have a buddy in cleveland Tn and he said that the 6V pressure plate has two different ones and didnt know if the one i have will work. so im thinking the worst thing to happen is it will mess up my TO bearing and and i will have to order a new clutch and pressure plate and lose bout a hour of work
- david58
Re: Clutches
The 3 finger style pressure plate shouldn't be a problem. As in messing up the throw out bearing.
SUBLEVEL88
Re: Clutches
guys im back reformated my computer and lost the website. good news we got to bug running today everything is going great so far just got to get the seats in it tomorrow and do a little wiring for the tail lights had to order the whole tail light assm. and i got a couple of wires crossed so im hoping by this weekend i will finally get to drive down the road been working on it slow for two years and its bout to pay off. thanks again guys for all your help
