Engine Lubrication
Posted: Fri Mar 07, 2008 1:44 pm
FJCamper wrote:
The above is a blast from the past, a 1950's Porsche 1.3/1,5 (roller crank!) Super engine. When VW guys take a look at it, they immediately see an engine they know...right down to the grandfather of the "Kadrons," actually 40mm Solexes. Kadron was just the name of the Brazillian company that sold a variant of the carbs beginning in the 1970's.
Porsche thought it had oil slosh control handled because of the design of the sump. Look how the sump narrows at the camshaft. The VW is the same.
356's had more oil capacity (3.5 liters with a later increase to 4.5) than a VW, helped because of a bypass filter system. And in 1960-61, they got whopping 36mm oil pumps.
Anyway, in 1960, Porsche made a huge improvement we all use today -- the windage pushrod tube. This is a tube with a simple but effective extension on the case end, which helps prevent oil from sloshing up from the sump into the heads.
An oil note: roller cranks could live with less oil pressure than plain bearing cranks, but Porsche developed the plain bearing crank to the point that we can get 7k+ out of one then and now.
When they dropped the roller cranks, they needed better oil control, and gave us the windage pushrod tube.
FJC
