Best Front Beam Adjuster: Avise vs Sway-a-Way
Posted: Sun Oct 28, 2007 10:53 pm
by spongeworthy
Hello everyone.
I'm looking for opinions on the best front beam adjusters for handling the abuse of off-road use.
The Avise ajuster vs the one Bugpack, Empi, Sway-a-Way etc sell.
Posted: Mon Oct 29, 2007 12:11 am
by 69bajakid
I have never had any adjusters fail...prob because i have never put them through allot of abuse..
but i have installed and used lots on street cars and a few mild bajas..
and the china empi jobbers are GARBAGE! thin steel..junk aluminum..junk grub screws..JUNK! dont use them..i welded in one and had to cut it out just because i could not bear to look at it any longer..
the SAW adjusters i have were much better quality..all around.. same style as the empi.. but just better..
BUT IMO i like the Avis style.. i have had a few sets of the avis adjusters and they seem to be fail safe..easy and quick to adjust...great quality..easy to install
i would go with the avis..unless someone here has had a problem with them?
Cale
Posted: Mon Oct 29, 2007 4:09 am
by petew
i've got the bugpack ones in my beam. i was told the avis were better, but i've never had an issue with mine. i'd personally say what ever you can get cheapest wins.
Posted: Mon Oct 29, 2007 6:12 am
by takotruckin
i've always heard the avis style were junk for offroad. i think ricko had one fail on him.
Posted: Mon Oct 29, 2007 6:27 am
by Leatherneck
Avis style are not the pick of the litter, the others will hold up better and take the abuse.
Street guys have better luck with the avis type.
Posted: Mon Oct 29, 2007 9:14 am
by rickosuave1987
Avis adjusters wont hold up off road. i made it all of 30 ft. before both of mine stripped out the teeth. Go with the SAW.
Posted: Mon Oct 29, 2007 10:12 am
by bajaherbie
'nuff said....
Posted: Mon Oct 29, 2007 11:39 am
by Big Dave
My adjusters (not Avis type) lasted a couple years, but finally stripped all the threads.
Do the cut and turn--that is the only way to ensure you'll have no problems. :wink:
Posted: Mon Oct 29, 2007 7:06 pm
by spongeworthy
Thanks, everyone.
I think I'll search for some real Sway-A-Way adjusters if I can find them. Most shops stock the super-crappy Empi adjusters and it seems that Empi can't make anything right these days.
As a side note...Years ago, Gary Avise himself made me a beam with his famous adjusters. He had a shop in Stanton at the time. It worked great on my lowered street Bug.
Posted: Mon Oct 29, 2007 7:13 pm
by Projectile Motion
Short of the pricey offroad shop near my house Eshocks is the only place I can find the SAW adjusters. Also for what it is worth most of the class 9 guys seem to prefer the cut and turn method. Good luck.
Posted: Mon Oct 29, 2007 8:27 pm
by sideshow
I'm no OHV person but my observation is that there maybe three Avis adjusters;
The ones Berg sells, coarse teeth DYI install
Puma type pre-installed in replacements beams coarse teeth
Clone adjusters much cheaper than the Berg ones, fine teeth
After installing real ones and puma beams, I bought and gave away the clone adjusters.
