Bob Ingrams ran this sharpbuilt setup also in his Thing.
http://www.sharpbuilt.com.au/dunebug.htm
Combi IRS gearbox into a Beetle chassis brackets and straps soft mount
Bellow is picture of it done in Baha Wes's bug, I added white comment:
I think they did this without a 10 degree saying:
The shifter rod then steps back down into the tunnel via 2 standard
shifter couplings welded on top of each other.
I have 3 questions can you please help:
1. What do you guys think about this sharbuilt method, could I use it in my Thing with a late moddle 002. Another words is welding the shift couplings on top of each other a good solution.
2. Would I have to modify the original Thing axles to accommodate the wider 002 tranny, if so how and would lifting the rear keep me from having to modify them?
3. Would I have to cut a hole in the bottom of the body or use a lift kit to get it away from the taller tranny?
