Voltage is like pressure
Posted: Sun Dec 10, 2006 8:07 am
Voltage is like pressure (the positive side of your battery being high pressure and the negative side being low pressure). Higher voltage allows the same amount of current to flow through a smaller wire, just as higher pressure can push more water through a pipe. That's why the wires for 12-volt systems can be smaller in diameter than those in 6-volt systems.
The big difference between plumbing an and electrical system is that plumbing only goes one way, but an electrical system must be a loop, or circuit. A circuit must also have resistance, in the form of a light bulb or accessory. If there is no resistance in the loop, it becomes a short circuit that can destroy the system and the battery and possibly cause a fire (resistance is measured in ohms).
A typical automotive circuit would be one for lighting. Current flows through a wire from the positive pole of the battery (on some earlier cars the polarity is reversed), through a switch, and then to a light socket and bulb. From there it goes through the bulb's filament (which provides resistance) then back through the car's sheet metal and frame, through the battery's ground strap, and into the negative pole of the battery.
The first step is to change your headlights, taillights, dash lights and horn relay to 12-volt. You'll also need to install an ignition ballast resistor between the ignition and the coil, which must be changed to a 12-volt coil. and of course a 12-volt battery has to be installed .
This car has good wiring so it won't be rewired until it's repainted. However, if the wiring is bad--which is more often the case--the best plan is to rewire the whole car from scratch with a pre-wired modular fuse block and wiring harness kit because the pre-'50s cars (and trucks) had no fuses. One bad thing about early electrical systems was the wire itself, which was covered with cloth insulation. Through the years, cloth would deteriorate and the bare wires would touch each other, causing the whole wiring harness to short out and catch fire.
Info was found at this URL and content edited
http://www.lowridermagazine.com/tech/04 ... ire_bomba/
