FAQ - body lift
72bajaben
FAQ - body lift
Post by 72bajaben »
What is the purpose of the round part in the back? Is it necessary? Its circled in red.
Starting to feel like a midget, cut and paste cut and paste.
Here ya go Ben shows it alittle better, gives you access to your tranny linkage for one, the other is makes a good question initiator.
Image[/list]
72bajaben
Post by 72bajaben »
hahaha thanks.
allsierra123
Post by allsierra123 »
did you make that yourself or is it a kit you bought?
72bajaben
Post by 72bajaben »
oh no....i havent made mine yet. i was just wondering. there are aot of guys on here that have made them. do a search for Body Lift. there are some good discussions about it.
allsierra123
how are these vs the ones you buy from different parts houses?
MNAirHead
Post by MNAirHead »
I have a few of the $200 magazine lifts.. they're NOTHING like this... tin c channel
72bajaben
Post by 72bajaben »
these are way better. it is solid tubing, the ones that you buy are a "C" style channel. and after time the top and bottom start to close in on each other. and then you have to weld a plate on them to fix it. so you might as well build your own. plus you can make it any size you want.
allsierra123
so in other words probably not worth the $200 unless you need a pattern to work from.
72bajaben
Post by 72bajaben »
yea i guess. but you might find a used one. i see them every now and again. but you culd buy it make a pattern and then sell it. and then send me a copy of the pattern :D
MNAirHead
Post by MNAirHead »
If doing it over... I'd watch the for sale threads... then buy a used rusty one... have them throw out the sides and only send the front & back...
I've bought used lifts ~$50...
allsierra123
lol Im not so hot with the fabbing.Im going to have to learn because Im seriously wanting a nice rack as well.And It seems that no one makes a nice one for a bug.I think someone could make some money starting to fab up high quality custom vw parts.
allsierra123 wrote: Im seriously wanting a nice rack as well..
Every man wants a nice rack on their ride.
All_talk
Re: body lift
Post by All_talk »
72bajaben wrote:What is the purpose of the round part in the back? Is it necessary? Its circled in red.
Why... to get my pic posted in muiltiple threads, why else, Ha Ha :)
I suppose there are simpler ways to leave access to the shift coupler, but I thought it would look good to follow the original contour. And it seemed to be the “no short cut” way to do things, and I like to go that route when I can. And in this case it wasn’t a mater of more money, just more effort. But don’t think I’m above a few short cuts, just look at my tranny mount in the other thread, in that case it is a matter of money (not ready to drop $600 on a tubing bender yet), and for now this project is on the down low budget.
And my lift is tin C-channel :P, well not really tin, but 16ga cold rolled steel. I didn’t like the idea of through bolts and wanted to use welded in nuts so channel was the best way, and like I mentioned in the other thread I will end up boxing in some sections to stiffen things up. For a lighter glass buggy I think it will be fine, for some thing with more body weight on it like a Baja the rec tube might be best.
Gary
