[quote="scott the viking"]Ya know....I really do like answering technical questions....But I feel kind of guilty for giving halfassed answers. The problem is...to give you a "wholeassed" answer would be a novel of technical jargon. In example...The compression ratio. Now...on a stock engine with a stock head (1600), I think the ratio falls somewhere around 7.8 0r 7.5 to 1. But heads are not the only thing that controls that..... Here are the things that have affect on "static compression ratio".
Bore-- The diameter of the cylinder bore
Stroke-- The distance the piston travels in the cylinder
Deck Height-- The distance between the top of the cylinder bore and the top of the piston, when the piston is at TDC (Top Dead Center, or at its highest position
Compressed thickness of the head gasket-- Usually 0.040", but varies with gasket manufacturer and application
Piston top volume-- If the piston is dished, domed, or dimpled, that has an affect on compression ratio.
Combustion chamber volume-- How much open space is in the head above the cylinder .
So...a real quick definition of static compression ratio (the one everyone talks about) is this....Lets say your cylinder with the piston at the bottom of the stroke has 10 units of volume...This is called swept volume. And when the piston is at the top of it's stroke TDC or top dead center, the swept volume is 1...what this give you in a static compression ratio is 10 to 1. So...the piston smashed ten units of air/fuel into 1 unit.
NOW...there is another type of compression...it's called dynamic compression. Dynamic compression has the same principals as static compression BUT...dynamic compression is NOT measured from the time that your piston is at the bottom of the stroke. It rather...is measured from the time that your intake valve closes and your engine actually starts to build compression. Okay...this can get REALLY advanced, but I will keep it basic (as I can anyway). You all have an idea of how a four cycles engine works I am sure...if you had no idea...then you stopped reading this about three lines in. On the intake stroke, the camshaft opens the intake valve the piston travels down in the cylinder bore, which greats a vacuum, which pulls in the fresh air/fuel mixture....I am leaving out SOOO many details if the intake stroke, like exhaust scavenging, overlap and such...but lets just say that the piston is going down the cylinder and it is sucking air/fuel in behind it because the intake valve is open. The piston goes all the way to the bottom of the stroke with the valve open, but the valve does not shut right when the piston reaches the bottom...the intake valve stays open as the piston is starting back up the cylinder. When (and only when) the intake valve closes is where you start to measure your dynamic compression ratio. Therefore, dynamic compression ratio is always lower that static. If you have a 10 to 1 engine (static) and you install a cam with a lot of duration (again, over simplified) your dynamic ratio can drop down to 7 to 1 or much lower. If your dynamic compression ratio DCR, falls below 7.5, then it is time to rethink your cam choice or up your static compression ratio to compensate. See...when I guy spouts off that he is running a 11 to 1 compression ratio, and he just runs super..well his camshaft size may have dropped his running compression ratio down to like 9.5 to 1 or so. Now if that same guy says he has a dynamic compression ratio of 11 to 1...tha's a different animal all together. So as you can see...there is A LOT to just the compression ratio of an engine...and this did not even begin to scratch the surface of it. So...for your question of changing the compression ratio of your air-cooled motor...sure...you can...just the way I explained above. But...higher compression also builds more heat, more heat can be a cause of detonation or hot spots. So you will have to compensate for this added heat to your engine...better oil cooler, more attention to your cooling tin, run better fuel. Running an air-cooled engine through the deep sand with paddles...all day in the heat...is hard on it with a low compression ratio...you up that ratio and you will have A LOT of other issues to address...sure...it CAN be done (I do it) but at what price? The answer is a lot.
