I autocross a ghia, and in that environment things happen so fast I don't have time to look at gauges...In fact, I've pointed out the my engine builder who encouraged me to install a tach, I've never once noted my RPM while on track!
But the very first thing I did was the 'big rig trailer' idiot light conversion. I used the gaping hole left by a 'din' sized radio to install two big red lights. (A piezo alarm speaker is coming soon) Many people have asked me which light is which? And I simply tell them, "I'm not racing for money, so if either of them light up I stop."
As far as changing sensor 'on' pressures? VW actually has a number of "on/off" sensors that will thread into the sotck hole with a variety of trigger pressures. I'll post a few part numbers, and trigger pressures, that should screw right in tomorrow.
If you REALLY wanted to get fancy, while keeping the whole idea of simple idiot light effectiveness, the reason for the different pressure switches, is that water cooled VW's have a "dynamic sensing" system...
This setup uses a basic logic circuit and two switches; A low pressure/normally closed switch, and a high pressure/normally open switch.
With this combo and an RPM signal, the light is triggered when pressure drops below 1.8bar at 2500RPM or above, but still works as normal below that.
