Correct use of a dwell meter...
Posted: Thu Sep 14, 2006 2:28 pm
Hi folks,
Hope this question isn't tooo trivial but...
I tried setting my dwell angle the other day and appear to have fried my meter; is this likely? The meter was the digital automotive multimeter type, not exactly el cheapo but not terribly flash either. I connected the red terminal to the #1, negative terminal on the (6 volt) coil, the same terminal that the condenser wire attaches to, and grounded it to one of the bolts that attaches the coil to the fan housing. I started the engine up and turned on the meter, nothing, dead, blank screen (it appeared to have been working beforehand).
So could I have fried it? The really high voltage only shoots through the centre coil post to centre of distributor wire, right? And its ok to measure dwell with the engine running (as opposed to just cranking over with the coil wire removed)?
I brought the meter back to the shop as it wasn't terribly old and declared it a POS; they replaced it without any fuss. But I don't want to destroy a second one without confirming that I at least have the procedure right first. Was it just coincidence that it failed at that time? Or did I do something completely wrong...
