This is as it sits just after I brought it home.
Larger Pic
Goodies I got with the car. Full set of Street tires/Rims and also Sand Paddles!
Larger Pic
Damage to the front of the car....
Larger Pic
Yanked most everything out...
Larger Pic
I am yanking the body off the pan at the moment. There is some fiberglass repair I want to do and also paint it Dark Blue with MetalFlake. I may try to get enough of the small things fixed to get it out on the sand for the 22nd.
It has a built up type1 transmission for Sand and a 1836cc motor. Has dual carbs which I am not fond of. Will see if I can get them dialed in.
I have to redo the turning brake somewhat as one of the brake lines snapped... Big project but I've always wanted a Manx Style buggy!
~Ryan B
UPDATE (7/17/06):
As I mentioned above, I was yanking the body off the pan. Well, the further I got into it the more things I found I didnt like.. Isnt that always the case though!?
Here the pan is off and I found the pedal cluster full of sand and badly rusted. The master cylendar was also pretty much shot. Decided I was going to clean up the entire pan and give it a simple spray paint job and also weld up the gaping hole where the e-brake was...
Larger Pic
Larger Pic
Here I've cleaned up the pan and welded in 14 guage plate over the hole. Yes, the side you see has ALOT of boogers... I had the wire feed up too high. The other side looks alot better!
Larger Pic
Larger Pic
1st coat of chip resistant black paint is sprayed on. I only bought one can though. Need to buy more. I'd like to get 3-4 coats on. Plus I have more drilling to do when I put in my other prake lines so need to wait on more painting.
Larger Pic
Larger Pic
So, since I didnt have the paint I needed and am still working out the front brakes... What to do??? Put together my disk brake system for the rear! 0o0o0oooo purdy!!! I also put on new gas shocks as well.
Larger Pic
Larger Pic
Larger Pic
Look Ma !! Rear tires!! Almost looks like a car again! Yes they are street tires. Still sourcing the rims for my rear paddles.
Larger Pic
So... I had been trying to tune my engine. Ran into a fuel delivery problem on the 3/4 side. I pulled the plug and noticed "crap" come out near the coolin fin area. Well time to investigate.. Glad I did. Oh my ....
Larger Pic
Larger Pic
Something decided to take up residence in there while the car was in "storage"... yeesh!
Well thats what I got done this past weekend...
Things to do near future:
Get Front drums re-installed.
Replace and repack front wheel bearings
Complete front brake system with some kind of "disable" function.
More paint coats on Pan.
Re-install and complete turning brake integration with new rear brake system.
Re-wire buggy body. Make removal of body easy with quick disconnect wiring.
Aquire aluminum lightweight 15x14 Rear rims for Paddle tires. 4.5 on 5 Chevy bolt.
Aquire aluminum lightweight 15x4 front rims for sand smoothies. 4.5 on 5 Chevy bolt.
Things to do far future:
Disk brakes on front.
Repair fiberglass hood.
Metalflake blue paintjob.
Full cage rollbar.
