Swivel adjuster to valve stem offset!!
Casey79Westfalia
Post by Casey79Westfalia »
Jake I have installed my rocker arms and noticed that one on the swivel feet hits the valve dead center. All of the other hit a bit off center of the valve. I know originally they were offest to spin the valve but should I be concerned. It appears that a additional spacer on the left side of the rocker in question would give it the proper offset. Just checking with you.
Post by MASSIVE TYPE IV »
With the swivel foot things are very forgiving. I tend to run them in most any position but if you can correct it with swapping the position of the shim that would be fine..
Casey79Westfalia
Great I will see if I can correct it. Thanks Jake!!
Locked
