2316 type4 engine.
Passatman
2316 type4 engine.
Post by Passatman »
Hi guy's/ jake,
What would be the benifits of putting a 2316cc engine in my bug. The gearbox have the following ratio.
1st 3.78
2nd 2.06
3rd 1.48
4th 0.82
ring and pinion is 3.88 ( german ).
tire size is 24.69 inch.
Post by MASSIVE TYPE IV »
According to the combo it could make 120-190HP on pump gas easily....
we all know what that does to a Bug!
The gear ratios are suitable for a 2316 power output, BUT thats a HUGE drop between 3rd and 4th gears... The 3.88 will magnify the "drop" even more..
Passatman
Post by Passatman »
Oh! my mistake the 3rd is 1.26. I think jake would say that this is still a big drop off from 3rd to fourth. The car is a 1200 bodied beetle.
1.26 to a .82 is no big deal... It works well.
Passatman
Post by Passatman »
Thank's alot jake for the help.
jboyton
gear ratios
Post by jboyton »
try this site:
http://www.et-studios.com/motorsports/gears/gears.html
plug in your info and you'll see the MPH vs RPM's
dstar
Post by dstar »
DAY-UM! :shock:
IF my 2316 will pull to 7000, I can go 184 MPH!
:shock:
Hope the Bradley can handle it!
:twisted:
Don
jboyton
Post by jboyton »
I figure that if I put 35" tires on the buggy, she'll be doing 212 MPH at just over 4700 RPM's........
Locked
