Jake, I am having a slight problem with my flywheel I bought from you. It appears the pressure plate bolt holes do not line up and there is some slop between the pressure plate and the flywheel. The holes in your flywheel seem to be smaller and are not 8x1.25. I think I might have the wrong pressure plate. 022 141 025G (sacs) Can you or anyone else give me any assistance?
Thanks, Jon
210 mm conversion flywheel problems (pressure plate)
- dstar5000
Did you run a tap through all the holes?
I couldn't get the bolts to go in either and thought that Jake had
sent me a 215 instead of a 210, cause the 215 had 7mm bolt holes.
I ran a tap through each hole and things started falling in place EASY PEASY!
IF the bolt holes don't line up, are you SURE you have a 210mm
pressure plate? A 200 T1 PP won't bolt up.......
IF the holes are clear, and you are sure you have a 210 PP, then
you probably have a 215 flywheel.
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- raygreenwood
The 215's...oddly enough ..came with 6mm bolts...at least on the 411/412. Many of the pressure plates built just for them.....and a few other 215's in other vehicles came with the pressure plate holes at 6mm to match the flywheel. You will have to tap the holes in the flywheel to 8mm. Then ream the holes in the pressure plate. I would not leave the 6mm bolts in there.
If you have 8mm's in the flywheel aready, then you simply need to ream the PP.
I always found this odd. All of the original 210's in the 411/412 came with 8mm bolts...and teh 215's with 6mm.
I think part of it is because in general, casting wise....they are actually pretty much the same part. You will notice that the flange area on the 215 is a hair narrower. I believe that is why they used the smaller bolt to have more meat around it.
Just re-read your posting....yep...thanks for the memory spark. They WERe 7mm. Just my brain damage kicking in. I always found that really odd. Ray
- sideshow
Damn, glad I read this. I just opened my RAT flywheel box and my 215 (to type 5) conversion flywheel has 8mm threaded holes that have a PDC to large for the 215 RAT/bus pressure plate (that look to have 8mm pass through holes).
What did I receive? receipt #977
thanks and a question
Hey thanks for the posts. I was under the impression I had a 210mm fly wheel but it would appear that I have a 215mm. I bought my pp and clutch from a local shop and will have to return it there. Thanks for the info.
Jake I was wondering if it would be possible for me to exchange my Flywheel for a lightened one?
