I then did one into an 091 in my ej22 Subaru powered Manx
I made them both cable operated moving to a push/pull cable to engage and disengage
Works quite well with a switch to tell you when it's engaged...
Since installing it I have done more beach work then offroading/crawling/climbing but it's been a blast so far. I think it will enable me to go into far more stupid places as my Manx already went quite well fast or slow down most trails
The biggest drama was coming up with a location to bore into the box casing for the actuator shaft and avoid everything, I managed to sneak it in between the ribs so I wasn't taking to much strength away also kept it up high above the oil level.
As far as strength goes.... Well I am a fraction of the weight of a syncro and I recently competed at a local drag racing event and it is still in one piece so I'm happy....
You can't beat being able to lock it in and out.....
