Six-seven Turbo Projekt
Hotrodvw
Re: Six-seven Turbo Projekt
Post by Hotrodvw »
That would be the best option.
Humpty
Post by Humpty »
Look tough too! :D
Hotrodvw
Post by Hotrodvw »
Header parts are back, and got my breather box today as well.
Hotrodvw
Post by Hotrodvw »
WooHoo!!! Lots going on in the garage tonight.
Humpty
Post by Humpty »
I reckon your exhaust is asking to head out through the jet portal.... Nice and neat.... But might make plug changes a bitch!!!.... Oh what the heck.... Oil drain looks a little small in diameter.... Looks lovely all the same! :mrgreen:
Hotrodvw
Post by Hotrodvw »
I have an idea of where I want it to go, not sure it's gonna go though. Plug changes will be easy. Oil drain is a -8.
I can't tell if you like it or not.... :lol:
Humpty
Post by Humpty »
Oh I like it plenty!!!
Vee Dub Nut
Post by Vee Dub Nut »
Looking sharp... can't wait to see the finishing touches on it!
HID GUY
Post by HID GUY »
Very nice work! the black looks good Eric :twisted:
Hotrodvw
Post by Hotrodvw »
Thanks guys....I'm ready to finish it and run it! :twisted:
Marty
Post by Marty »
NICE!
MarioVelotta
Post by MarioVelotta »
Can you give any pointers on bending bending hard line so nicely? I have always had a hard time doing a good job with that.
[email protected]
Hotrodvw
Post by Hotrodvw »
http://www.swagelok.com/downloads/webca ... -13-43.pdf
This pdf file has some good info as far as making bends. It all boils down to measuring correctly, and knowing the bender.
Look at pages 15 thru about 25.
If you want a 90 bend, and 4 " leg on end end, you have to measure 4" from the end. This will put the 90 leg, 4" at the centerline of the tube, not the out side edge. To do this, you line up the zeros on the slide block and the bender. The mark you made @ 4", goes on the 90 mark on the slide block. ALWAYS work in one dorection. If a certain layout requires you to make a bend the other direction, you have to put your mark on the R. This is for reverse bends. The tubing will grow, this is why it's so important. Anyways.......read that file, it has good info.
Eric
ToRy 70
Post by ToRy 70 »
Looks excellent. Good wastegate placement!
Coyote
Post by Coyote »
Looks good !
are you using a AN4 for oil feeding? with or without a restrictor?
May be I am wrong but : is it really a good idea to install the oil drain at the generator stand? is it possible that a lot of oil will try to reach the breather box instead of returning in the crankase? if you are using a vent here of course ! :lol:
2276cc daily draw though
ET: 11.67
MPH: 119.64
