Page 6 of 8
Re: New Type 4 Trigger Wheel
Posted: Thu Aug 08, 2013 7:43 pm
by Steve Arndt
Hey Lance, you should post some info on the low emission USPS conversions you are involved with on EFI 101. I would love to hear more.
Posted: Fri Aug 09, 2013 1:05 am
Those are for
Motorcycles so they cost 2X as much. At least.
(I'm used a Dyna ignition to run those DIS coils on the old Wing... If it ever rolls again it will be `squirted)
Posted: Fri Aug 09, 2013 8:08 am
by luftvagon
IGN-4 Coil mount bracket -- From motorcycle license plate prototype to steel mount:
Posted: Sun Aug 11, 2013 7:04 pm
by luftvagon
I got the hall sensor wired up, and I am getting loss of sync : 2 (missing tooth at wrong time). I did not have the ignition hooked up.. dry run.. log attached:
Posted: Sun Aug 11, 2013 7:34 pm
by MarioVelotta
How about with number of coils set top wasted spark?
Posted: Sun Aug 11, 2013 7:37 pm
by luftvagon
MarioVelotta wrote:How about with number of coils set top wasted spark?
I just noticed that. I'll give it a shot tomorrow. So far soo good.
Posted: Sun Aug 11, 2013 8:20 pm
Time after spark is also not the setting you want.
(unless you have an old SAAB with Trionic system)
If you have recent firmware the little tooltips (? boxes) are quite useful these days.
(The devs have worked hard on them)
Posted: Sun Aug 11, 2013 8:23 pm
by MarioVelotta
Oh yeah, didn't notice that. I was on a jog, lol.
Posted: Sun Aug 11, 2013 8:24 pm
I'm taking a break from putting a convertible top on... I bet I'm sweating harder
Posted: Sun Aug 11, 2013 8:49 pm
by MarioVelotta
Piledriver wrote:I'm taking a break from putting a convertible top on... I bet I'm sweating harder
True that
Posted: Fri Aug 16, 2013 2:10 pm
by Rikard
A squareback convertible... what a sight
Posted: Fri Aug 16, 2013 2:41 pm
Rikard wrote:Piledriver wrote:I'm taking a break from putting a convertible top on... I bet I'm sweating harder
That's been done, this one was just getting an 86 Cabby back on the road.
(Purpose: so I can drop the motor in the square and fab the AC bracket properly)
Posted: Sun Sep 01, 2013 6:13 pm
by luftvagon
I need help... Crank Crank Crank Crank Crank.. backfire.... sometimes it starts, but shuts off as soon as you let go off the starter.
IGN-4 Terminal Pin 3 goes to white 14 gauge wire on the quadspark, thats connected via yellow wire to IGN-OUT1 (white)
IGN-4 Terminal Pin 1 goes to green 14 gauge wire on the quadspark, thats connected via light-green wire to IGN-OUT2 (white/red)
IGN-4 Terminal Pin 2 goes to 7.5 AMP fused and switched +12v.
IGN-4 Tower #1 goes to CYL #1 } supposedly triggered by pin #3
IGN-4 Tower #4 goes to CYL #3 } supposedly triggered by pin #3
IGN-4 Tower #2 goes to CYL #2 } supposedly triggered by pin #1
IGN-4 Tower #3 goes to CYL #4 } supposedly triggered by pin #1
Code: Select all
IGN-4 Label Cyl Spark Output
[ 4 ] [ 3 ] [ 3 ] [ 4 ]
[ 1 ] [ 2 ] [ 1 ] [ 2 ]
pin |3 2 1| |3 2 1|
Thanks
Posted: Sun Sep 01, 2013 8:03 pm
Set it to 10 degrees fixed advance and take a trigger log/post.
I defer to IGN4 users as to dwell settings.
Posted: Sun Sep 01, 2013 8:28 pm
by luftvagon
10 degrees on the ignition map?
