New Type 4 Trigger Wheel
Steve Arndt
Re: New Type 4 Trigger Wheel
Post by Steve Arndt »
Hey Lance, you should post some info on the low emission USPS conversions you are involved with on EFI 101. I would love to hear more.
Those are for Motorcycles so they cost 2X as much. At least. :lol:
(I'm used a Dyna ignition to run those DIS coils on the old Wing... If it ever rolls again it will be `squirted)
luftvagon wrote:Image
luftvagon
Post by luftvagon »
IGN-4 Coil mount bracket -- From motorcycle license plate prototype to steel mount:
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
luftvagon
Post by luftvagon »
I got the hall sensor wired up, and I am getting loss of sync : 2 (missing tooth at wrong time). I did not have the ignition hooked up.. dry run.. log attached:
MarioVelotta
Post by MarioVelotta »
How about with number of coils set top wasted spark?
[email protected]
luftvagon
Post by luftvagon »
MarioVelotta wrote:How about with number of coils set top wasted spark?
I just noticed that. I'll give it a shot tomorrow. So far soo good.
Time after spark is also not the setting you want.
(unless you have an old SAAB with Trionic system)
If you have recent firmware the little tooltips (? boxes) are quite useful these days.
(The devs have worked hard on them)
MarioVelotta
Oh yeah, didn't notice that. I was on a jog, lol.
[email protected]
I'm taking a break from putting a convertible top on... I bet I'm sweating harder :lol:
MarioVelotta
Piledriver wrote:I'm taking a break from putting a convertible top on... I bet I'm sweating harder :lol:
True that :mrgreen:
[email protected]
Rikard
Post by Rikard »
A squareback convertible... what a sight :shock: :wink:
1977 Bus, 2.0L Type 4 engine, webcam 107i
MS2 Extra, direct fire EDIS Coil
That's been done, this one was just getting an 86 Cabby back on the road.
(Purpose: so I can drop the motor in the square and fab the AC bracket properly)
luftvagon
Post by luftvagon »
I need help... Crank Crank Crank Crank Crank.. backfire.... sometimes it starts, but shuts off as soon as you let go off the starter.
IGN-4 Terminal Pin 3 goes to white 14 gauge wire on the quadspark, thats connected via yellow wire to IGN-OUT1 (white)
IGN-4 Terminal Pin 1 goes to green 14 gauge wire on the quadspark, thats connected via light-green wire to IGN-OUT2 (white/red)
IGN-4 Terminal Pin 2 goes to 7.5 AMP fused and switched +12v.
IGN-4 Tower #1 goes to CYL #1 } supposedly triggered by pin #3
IGN-4 Tower #4 goes to CYL #3 } supposedly triggered by pin #3
IGN-4 Tower #2 goes to CYL #2 } supposedly triggered by pin #1
IGN-4 Tower #3 goes to CYL #4 } supposedly triggered by pin #1
Code: Select all
  IGN-4 Label        Cyl Spark Output
    [ 4  ] [ 3 ]               [ 3 ] [ 4 ]
    [ 1  ] [ 2 ]               [ 1 ] [ 2 ]
pin  |3 2 1|                    |3 2 1|
Set it to 10 degrees fixed advance and take a trigger log/post.
I defer to IGN4 users as to dwell settings.
luftvagon
Post by luftvagon »
10 degrees on the ignition map?
