Mark's turbo ghia buildup.
Clonebug
Re: Mark's turbo ghia buildup.
Post by Clonebug »
Why the removal????
WickedWagens
Post by WickedWagens »
The car is changing directions into a race car to run at Bonneville. I want to run in the "Classic" category which allows no computer controlled ignition or fuel management. I'm toying with the idea of a blow through 4 barrel or may end up draw through. The megasquirt EFI will end up on my 181 Thing.
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
joosep
Post by joosep »
How can U stay on this seat with so hot engine? Your leg and arm must me painful after some little run.
andy198712
Post by andy198712 »
Wow thats some surgery!! glad your ok!
WickedWagens
Bars going in!
Top Speed 174.2 MPH
WickedWagens
Some progress from today. Instead of a 4x5 inch support pad we decided to just run the 1/4" along the whole side.
Top Speed 174.2 MPH
WickedWagens
A couple more bars today!
Top Speed 174.2 MPH
WickedWagens
Here is a quick update to get this back caught back up. here is how the cage turned out.
Top Speed 174.2 MPH
WickedWagens
I wasn't going to have any turbo engines done for Bonneville, so we put in an 1807cc normally aspirated engine and ran at Speedweek setting a record at 106.420 MPH. I then bumped up the compression and bolted on some goodies (recommendations and help of FJCamper and Retro Racing) and set another record at World of Speed running an average of 113.131 mph. Now its back to the turbo engines to get some real speed and see what records we can go for in 2017.
Top Speed 174.2 MPH
Post by Chip Birks »
Looks real good! Nice job on the back to back records!
petew
Post by petew »
That's awesome!
What's inside an 1807cc motor?
WickedWagens
The 1807cc 76x87 had a 76mm CB crank and 87mm Mahle pistons and cylinders, 110 cam, 1.25 rockers, cleaned up stock heads cut to 10:1 compression, and dual Kadrons.
Top Speed 174.2 MPH
petew
Post by petew »
That's cool. I've always wondered about building a mini stroker like that. Sounds fun. :)
MarioVelotta
Post by MarioVelotta »
Been awhile since you've updated this thread :)
[email protected]
WickedWagens
I decided to do individual updates since I have ran a few different engines in it.
1516cc Turbo
1516cc sidedraft turbo
1915cc Turbo
11915cc draw through turbo
Top Speed 174.2 MPH
