Page 5 of 5
Posted: Mon Jun 07, 2004 10:55 pm
by KDF Lad
We have an Aussie engine builder now providing heads (044 I think) with twin spark plugs. Slight reduction in advance, big improvements in low RPM range.
Stay tuned!
Posted: Tue Jun 08, 2004 12:49 am
by Wally
Thats nice KDF!
Do those heads have wbx or type 1 head stud spacing?
Thanks,
Walter
Posted: Tue Jun 08, 2004 1:45 am
by KDF Lad
T1 I guess.
Is that no good?
Don't the stud patterns get relocated to suit T1 anyway? (I'm a novice!)
Posted: Tue Jun 08, 2004 5:33 am
by Guest
i belive the yamaha 97 cylinders refered to at the beginning of this thread were off a snowmobile i've read of this before on a couple of sweedish cars
Posted: Tue Jun 08, 2004 9:10 am
Good info, anybody know what model?
Snowmobiles are 'kinda scarce `round here, which is not an accident on my part. After 10 years in Upstate NY, all winter getting lake effect snow almost every night by the foot, I'm kinda "burned out" on snow.
There were many days I could not tell the bus from the Golf in the driveway... The piles of snow were the same shape and size.
It DOES snow in N Texas rarely, but the next day it's likely to be 70 F, and poof, it's gone.
Posted: Tue Jun 08, 2004 1:02 pm
by Wally
Anonymous wrote:i belive the yamaha 97 cylinders refered to at the beginning of this thread were off a snowmobile i've read of this before on a couple of sweedish cars
Yeah, I agree, good info!
Could you specify the models which we need to refer to a bit more?
Would be great!
@KDF: yes, they get relocated, but not necessarily if you have read this thread from the beginning!
The Yamaha 97mm Nikasils are also used in the original wbx stud-spacing. Otherwise, a 97mm bore would never be possible
Greetings,
Walter
Posted: Wed Jun 09, 2004 12:09 am
by Guest
sorry cant tell you a model the feature just said snowmobile
is there any sweedish people on here
Posted: Mon Jun 14, 2004 8:03 am
by jonas_linder
sure, but I don't know anything about snowmobiles
Re: Aircooled wbx heads
Posted: Wed Nov 04, 2009 2:12 pm
by aircooledWBX
Hi,
i found this site when I searched for other aircooled-WBX builders.
Very interesting Thread !
I'm building an 76,4x103 engine with Limbach Heads an 42/37,5 Valves.
Here are some Pics:
http://picasaweb.google.com/Nick1303H/1200er#
One says, you can't use bigger bores than 96mm, or bigger Valves than 40mm.
Yes you can ! I'll see how long it works. I heard about an 82x103 engine that works great !
Greetings from Germany,
Nick
Posted: Wed Nov 04, 2009 4:23 pm
Welcome to the STF!
VERY interesting pics!
Are those modified T4 jugs?
Posted: Thu Nov 05, 2009 7:39 am
by aircooledWBX
Thanks !
I dont know what "jugs" means, my dictionary said it means "tits"
If you mean the cylinders, yes they are !
The water-to aircooling modifications already were done when i bought this parts.
The previous owner had two many projects, so he sold them.
However, I think the combustion chambers still need some work. As you can see on picture 48 theres an edge
on the valve seat. Needs some welding I suspect.
If anyone wants some detail-pics, of the case or the heads , tell me.
Maybe I should open an own Thread !?
Posted: Thu Nov 05, 2009 7:46 pm
by Unkl Ian
Very nice, I'd suggest smoothing the sharp corners in the combustion chambers.
Not sure how well the cylinders will cool, being so close together.
Air flow between the barrels will be kinda limited.
Posted: Thu Nov 05, 2009 8:36 pm
aircooledWBX wrote:Thanks !
Oddly enough, that's exactly what I said when I saw your pics!
(slang=="great")
I'd definitely start your own build thread, you have a very cool project!
