911 heads
Thought is they have blown motor issues, but you would need a 3.4 for the bore size.
Might pick up cheap, might be close enough to make viable bits on a T4, just saw off a cylinder/little welding
Water cooled DOHC 16v heads... Yum.
Might be interesting, don't have the familiarity to say, but Jake might, as well as others. They don't fall out of trees here, but I'm perhaps not in the right circles, so to speak.
(Just poking the beehive)
M-Owen
I cut up a head from a 996 recently and I am convinced that with some welding, machine work that could indeed work. I think if you used Aluminum cylinders and welded them to the head like Porsche did with their early watercooled GT-2 engines ( I think they used a type of welding called Electron beam welding). If I can get thru my current project with out pulling any hair out...it might be worth trying.
Cool.M-Owen wrote:I cut up a head from a 996 recently and I am convinced that with some welding, machine work that could indeed work. I think if you used Aluminum cylinders and welded them to the head like Porsche did with their early watercooled GT-2 engines ( I think they used a type of welding called Electron beam welding). If I can get thru my current project with out pulling any hair out...it might be worth trying.
I strongly suspect there are aluminum brazing techniques that would be ~ as strong as 356 aluminum would be EB welded, and might allow rework assuming a re-heat treat was performed. I'm thinking finned jugs ans WC heads.
Brazing also allows parts with somewhat different expansion rates to play nice.
EBW is Expensive.
Ian, you of ALL people should understand why !!!Unkl Ian wrote:Why do you need to weld barrels onto heads ?![]()
... Same reason Porsche electron beam welded jugs on their high boost racing engines...
...No head gasket...
No head gasket to leak.
T4/98x66... water cooled 16V OHC... one piece cylinder/jugs...good T1 Hbeams... How much boost/RPM could it take? (hey, might work for the LSR project you were looking at)
- Frallan
That WAS clear and nice.
I love those ideas.
Some similarity to my old rough SC TIV engine with watercooled heads and aircooled aluminium cylinders. In fact it was 98 bore and 82 stroke.
That is an idea to consider. I am in Miami today with my old dragracer and friend who is a car auction buyer&dealer. We are to attend an auction this morning, now I have a good idea to look out for a blown Boxter.
Very inspirational.
I still have the old Oettinger /Mahle alumnium nicasil cylinders lying around. Needs new plating and custom pistons but why not?
I see a hybrid water/air cooled 98x66 with a whipple on top of it....:-)
I love those ideas.
Very inspirational.
M-Owen
You might find that early 996 heads are easier to find than Boxter heads. The 996 was prone to cylinder failure in it's early life. I found a set on EBay that were loaded with cams and all.
I would stick with EB welding simply because it's more precise and does not leave much warpage. This is the type of welding I used when putting my experimental cam towers together. This way crazy amounts of boost could be seen with out leakage. Some of the brazing might work but I question it's overall stability But then again in my line of work we usually come up with an idea and others implement them so I could be wrong...who knows
- Unkl Ian
The 3 main crank will become a problem sooner or later.
The Bonneville idea has been delayed;at least.
Probably for the best.
Piledriver wrote:
Ian, you of ALL people should understand why !!!![]()
M-Owen
Hey can someone tell me why it's not a good idea to have my heads slightly offset, it seems that at 3mm per side the offset would be slight and with the proper relief in the pistons one could live with this.. I am asking this question before I cut the center out of a set of cam towers and rejoin them.
- Frallan
