A fast burn chamber is where its at. If you have to run tons of ignition lead it says you are doing something wrong. Negative work. I know what works for me, and I know my NA 2276 would smoke your turbo Ghia. Lets race
I can run lots more timing but it is a baja bug that I really off road, so often I can only get OLD 89 octane gas at remote filling stations.
Steve
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by danimal:
<B>>>>I have already done the testing, on the dyno and on the street. I know what added CR can do, on both ends of the spectrum...Lets prove it...<<<
without knock sensors you haven't done squat, because you don't know when the engine is at incipient knock.
so you'll never be able to make the maximum reliable h.p. that a new car does.
and how do you expect to prove anything on a dyno without knock sensing capability? lol... jake, i suppose you could improve your stone age tuning techniques by putting someone out there with a broomstick against the side of the case... i nominate dave cormack
>>>on the said 2276 and drove it 750 miles round trip to SLC from Boise and back this August in 102 degree heat.<<<
yeah, but at only 26 degrees advance... sounds like another caveman using audible knocking to tune his motor.
steve, before you start screwing around with that engine, how about running a few tanks of race gas thru it, with the timing set at 30-32 degrees... i'd like to know if that engine reaches it's optimal h.p. when there is enuf octane to feed the compression...
why? because a 10-degree spread in timing over the optimal mid-point can change the octane requirements by 8 or more points... there can be a lot of power lost when the timing is retarded from optimal.
dan
oceanstreetvideo.com </B><HR></BLOCKQUOTE>
