Starter fo 2.2 Subaru in '73 Superbeetle ?????
- panel
Re: Starter fo 2.2 Subaru in '73 Superbeetle ?????
Looks like this is a good p/n 357972771 if anyone else is looking to get one etc.
Just another confirmation that this starter works for a Type 1 trans with a ej25. I used a rotary burr and it took a 5 mins and a few test fits but it fit great and was able to use the big dumb 17mm nuts that held the stock VW starter.
You can see the template i made and how much i had to remove. Hope this helps the next guy!
IMG_20230830_173636 by Travis L, on Flickr
IMG_20230830_175650 by Travis L, on Flickr
IMG_20230830_180219 by Travis L, on Flickr
IMG_20230830_180102 by Travis L, on Flickr
IMG_20230830_180100 by Travis L, on Flickr
- Kafer_Mike
FYI for others looking to do same TDI starter swap... https://dunebuggywarehouse.com/products ... gItlPD_BwE
"Build 'em fast...or let 'em sit"
That plate would adapt a manual tdi starter: the automatic starter throw is correct without a spacer. The manual version has a longer nose.
Do make sure to get the 9 tooth gear version.
The manual tdi starters are easier to find, but that plate basically doubles the up front cost, but then you dont have to mod the starter.
Got a typical parts house version on my beetle.
Works well. The fit is a bit tight as the solenoid is above the main body so close to the parcel shelf. I also needed a longer bolt and gearbox stud.
