'68 Westy and a K20a swap...I ain't right ;)
- supaninja
Re: '68 Westy and a K20a swap...I ain't right ;)
Pile- I have a 091 laying around
I'm working a huge turn around so I can afford to have Rancho go through it, I want some taller gears and a LSD
viewtopic.php?f=14&t=140387
- fl_buggy
I have a 2.2 Ecotec in mine, and while I have an 091, I also am running VERY short tires (205/50-16). I was able to get 22mpg from mine, so yeah, I would say 20 should be easily attainable for him.
gearheadgreg
Coolness.
I've got an 091 in my '71, seems like the go-to box!
- supaninja
Greg, the 091 is the strongest box VW made. I definitely need taller gears, the 002 has the motor turning at 4400 when i'm cruising at 70 and 4100 at 65. I think i'll be fine cruising at 65 turning 3100. Does anyone know if swapping a 091 with a early 002 bellhousing will move the engine back?
Steve Arndt
I have an 091 with 002 housing in my bug, and I have spare 091s. I could take a measurement or two.
Steve
My Baja Build
My Baja Build
The automatics are stronger than an 091.
(The tq converter takes a lot of the shock out of the system)
I don't know if the front trans mount setup is like my 73s, but I could bring the trans forward a couple inches if I trimmed the shifter rod to match.
I have been considering an automatic for strength reasons... AFAICT the only "choice" in the NA market would be 3.9 or 4.10 final drive in the T3/T4 cars, or 4.10 in a Vanagon transmission.
(Info pulled from "Without Guesswork" and various online sources, hard to get a simple yes/no when most of the sources don't differentiate between NA and European markets...)
According to the info I have found, all North American market FI T3s were 3.9 final, the 3.67 final was euro only dual carbs.
The 411/412s were all 4.10 AFAICT (Some 411s may have had the 3.9).
(if anyone can correct this, please do)
The Vanagon has a higher stall converter (~2500 RPM with an MV spinning it)
There is a custom tall R&P for the vanagon trans (for suby swaps etc) but it's cost makes a Subarugears setup look like a killer bargain.
Also considering a 901 swap, it's also as strong or stronger than an 091, except for first, and has many gearing options... Still expensive to implement any of those gearing options.
- supaninja
Steve- that would be awesome!
Pyle- I'm going the KISS route on this plus I already have a 091 that I got from Russ Wolfe right before he passed away, it would be awesome to use it.
- RonW
Love seeing the continue progress on this
What a small world, Russ was my uncle and as a kid visiting Iowa, I hung out with is son Mark. Talk about a huge stash of VW parts even 30 years ago.
912R + STi 2.0 Turbo JDM v8
Steve Arndt
Nick, remind me on face book tonight and I will try to get those measurements when I'm at my shop.
Steve
My Baja Build
My Baja Build
- supaninja
My condolences Ron, Russ is still sorely missed in the type 3 community. His stash of parts was insane, lots and lots of everything.RonW wrote:Love seeing the continue progress on this.
- supaninja
Here is the exhaust after blasting it, getting ready to ceramic coat it and insulate the insides.
I used Cerakote Glacier Silver to coat the exhaust for the K20, and Insulakote inside the exhaust. It's amazing stuff and easy enough to use for a dummy like me.
It's hard to see in this pic but I wrapped the header and the pipe. Notice how close it is to the radiator, that's why I'm doing all of this heat management. So far the numbers are looking good for lowering temps but the real test is the southern Texas summer.
New roof rack
I'm currently dailying it to see how she does, I got the bluetooth finally working on the megasquirt and my android so I have been rocking MS Shadow Dash...what an awesome app, when it works, it's a bit unstable.
- MarioVelotta
Nice
[email protected]
[email protected]
- supaninja
Mario, do I have something wrong. MS Shadow Dash seems a bit glitchy, sometimes it works awesome, other times it drops out every 30 seconds, then other times it completely craps out. Is the app buggy?
- MarioVelotta
Try MSDroid you can actually tune with it. Plus it will pull the GPS from you tablet and you can plot it on a google maps to show your tripsupaninja wrote:Mario, do I have something wrong. MS Shadow Dash seems a bit glitchy, sometimes it works awesome, other times it drops out every 30 seconds, then other times it completely craps out. Is the app buggy?
I haven't used Shadow dash in quite awhile. I don't get to drive my car much these days.
[email protected]
[email protected]
- supaninja
I have been using msdroid too, i need to mess with the settings more, i want realtime speed too.
