My first Car, Bug and, Build
TimS
Re: My first Car, Bug and, Build
Post by TimS »
Devastator wrote:
Hedrock wrote:I like Dan's parts. Service and tech info is good and he is a contributing member here as well.
X2!
Agreed, and their website is one of the best, too. Wasn't sure how politically correct is was to give a bias opinion, but they will treat you right.
I was looking for something this morning (my desk is about as messy as my garage) and ran into what I think is the manufacturer of the Orange (heavier duty than the black colored Brazilian pan halves): Floor Pan Supply, "Wolfsburg West" in Corona, CA (951.549.0525.
http://www.wolfsburgwest.com/wolfsburg_ ... or_pan.cfm
I did look at their web site (above) and the floor pan comes in sections like the one I got so I am pretty sure this is the one.
greenbajamachine
Post by greenbajamachine »
ordered my parts yesterday coming tomorrow. put my irs clips in and get my trailing arms on.
greenbajamachine
Havent been on in a few days. i hope to be getting 3x3s now a guys trading me. need to find axles what size length will i need.
TimS
Post by TimS »
http://www.swayaway.net/joomla/images/I ... ctions.pdf
If you have time and want to avoid any issues, I would recommend setting up the rear end and then measuring axle length. You will read about a lot of folks frustrated with axle lengths when they try to "just guess". Look at the link above. Be sure to have the arms installed, stubs torqued, and alignment set. You may want to leave the torsion bars out so you can move the suspension easily to measure. That's the best way.
Instead of the "setup axle", I used two pieces of 1/4" wooden dowels.
Devastator
Post by Devastator »
ts39136 wrote:Instead of the "setup axle", I used two pieces of 1/4" wooden dowels.
I used 3/4" PVC pipe. It fits well inside the CV's.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
greenbajamachine
also can i use the axle stubs i have now or just get new ones
Devastator
greenbajamachine wrote:also can i use the axle stubs i have now or just get new ones
For figuring out the axle length, yes. Whether or not you use them depends on which CV's you plan to use.
Sandrail
going fast enough."
Mario Andretti
greenbajamachine
thanks answered both questions
beetleguy
Post by beetleguy »
I used 1/2"x2" square tubing and framed along the heater channel where the floor pan originaly bolted. I left a inch wide flange around the edge where the floor pan was welded to the tunnel. then i sandwiched a sheet of aluminum in between the flange, new metal frame and heater channel. I had to use the original floor pan as a template to get the holes all lined up. If I could have found replacement pan halfs locally I would have saved myself a ton of time, and probably achieved basicly the same thing.
greenbajamachine
any pics
greenbajamachine
looking for someone who can help me down in socal area...with welding in the irs mounts
rickosuave1987
Post by rickosuave1987 »
Do you have the jig for the pivots? I've got a welder and I'm in glendale...
Baja
HookIt
SuaveRacing FaceBook
greenbajamachine
i do have the jigs i also have a welder... if yours is bigger its good. not to sure how good mine is. your about a hour 30 min away send me a pm
greenbajamachine
Got the right side where the irs clips going to go done today.
Let me know you know what you think.
