70dragbug wrote:My questions are:
How does displacement fit into this picture
I´m building a 103x88 turbo type 4 - so would what would I be looking for in a cam? More duration,more overlap or more lobe seperation? It´s not really for drag racing use - more roadracing actually.So throttle response and overall power are important to me.
I realize that a certain amount of overlap is required to allow a good scavenging of the cylinder - even in a turbo application.Does this increase when increasing displacement?
The larger the engine, CI, the more one can get away with more duration. A 3.0 engine has alot more torque than a 1.6 engine, even if the RPM bands are the same.
I would shoot for .254 to .260 duration at .050, LSA 108 or less for NA, 108 or more for turbo.
No, your head design, port size, exhaust size, compression, CFM flow, will determine your cam duration. The cam duration along with the proper balance of head flow will determine the RPM band no matter what the CI's are.
