Page 36 of 37
Re: FI Build Up - Vee Dub Nut Build #2
Posted: Sat Oct 20, 2012 9:00 pm
by MarioVelotta
Vee Dub Nut wrote:MarioVelotta wrote:Sweet Adam, I have found COP's take a pretty small dwell. Less than 2ms running. You could start there.
Thanks for the tip... I saw some quotes of 1.2ms on the MSExtra boards for the type coils I'm (going to be) running.
There you go
Posted: Mon Oct 22, 2012 7:03 am
by Devastator
Steve Arndt wrote:CB are siamesed vacuum lines,
What do you mean by this? I'm in the process of designing ITB's and would like to design the preferred option.
Posted: Mon Oct 22, 2012 7:23 am
by Vee Dub Nut
Devastator wrote:Steve Arndt wrote:CB are siamesed vacuum lines,
The GSXR and Redline ITB's have individual vacuum nipples comeing off each port, the CB ITB's pair up the two ports internally and only have a single vacuum nipple off each side.
Posted: Mon Oct 22, 2012 9:08 am
by Devastator
Vee Dub Nut wrote:The GSXR and Redline ITB's have individual vacuum nipples comeing off each port, the CB ITB's pair up the two ports internally and only have a single vacuum nipple off each side.
I see. Thanks.
Posted: Tue Oct 30, 2012 10:56 am
by Vee Dub Nut
Nothing much new to report....
I attempted the COP mods but ran into problems (see:
http://www.shoptalkforums.com/viewtopic ... 6&t=140723) I'll regroup on this and try again with the drivers mounted in their own case to see if that makes any difference. The standby will be to continue to use the old Ford EDIS coil pack directly controlled for the time being.
Still trying to plan out the GSXR itb conversion.. I think I've mostly ruled out using the on board injectors on the ITB's due to clearance problems with the shroud and body. That leaves running something like the CB IDF efi intake manifolds, or welding my own injector bungs on my IDF intakes. Haven't committed to either direction just yet..
I do have some spigot boots coming, but am unsure if they will be included in the final mount design or not. My biggest challenge in my mind is getting pressure ducting to the top of the GSXR ITB's, as there isnt much shoulder on the top of the ITB to clamp silicon couplers to, so I'm still playing with the oringed plate idea on top to allow off the shelf CB turbo hats to be used. We'll see...
Posted: Tue Oct 30, 2012 11:19 am
by Chip Birks
What new direction are you planning as far as the turbo is concerned?
Posted: Tue Oct 30, 2012 11:25 am
by Devastator
Vee Dub Nut wrote:I do have some spigot boots coming, but am unsure if they will be included in the final mount design or not. My biggest challenge in my mind is getting pressure ducting to the top of the GSXR ITB's, as there isnt much shoulder on the top of the ITB to clamp silicon couplers to, so I'm still playing with the oringed plate idea on top to allow off the shelf CB turbo hats to be used. We'll see...
PM sent.
Posted: Mon Nov 12, 2012 12:02 am
(primary injectors Bosch EAT255 are 225cc and the secondary injectors Bosch EAT256 are 460cc, totaling around 65lbhr overall)
You should post that over at msextra, there's an injector size thread.
I'm still wondering what the Yamaha FX160 injectors i'm running work out to, identical physical fit but a light tan color, no EAT# on the side.
GSXR injector fuel flow rating EAT255 EAT256
Posted: Mon Nov 26, 2012 10:18 am
by Vee Dub Nut
Well another month passes and the car is still basically sitting in the same spot.. I always seem to manage to take the car apart during some of the nicest driving weather Texas has to offer. The last time I drove the car consistently it was near 100F... Now the weather is perfect
Posted: Mon Nov 26, 2012 11:25 am
by Vee Dub Nut
Posted: Mon Nov 26, 2012 3:32 pm
by supaninja
I know the feeling, I got so far as a TP dry sump, ceramic type 4 lifters, and a MS3x with all the fixin's for my turbo build, when out of the blue a bus got into the picture, lol.
Nothing sounds as good as a sweet turbo setup but them GSXR ITB's do sound bitchin when you get into the resonance rpms
Posted: Wed Nov 28, 2012 9:26 am
by 56speedster
One things for sure - you buy (and build) nice stuff so you never have any problems getting rid of it quickly.
Posted: Thu Dec 20, 2012 7:27 pm
by Vee Dub Nut
Posted: Sun Dec 30, 2012 5:18 pm
by willo357
Sweet build mate... just scanned the thread so far but looks like there is heaps of interesting stuff in here.
Posted: Sun Feb 24, 2013 3:56 pm
by Vee Dub Nut
Just an update to this thread...
After some other distractions and projects over the past few months, I ended up parting out this entire setup since last December. I've been toying with a lot of different ideas for its replacement, such as another T1, WBX, and a type 4. Big factors I wanted to address was better driveability (hence the intake I was working on), addition of an air/water intercooler, and a cooler running engine (I was always fighting CHT on this last build). All of my ideas (even another T1) were different enough from this combo, that selling off everything made sense, as I was looking at all new components anyways....
So after a lot of thought, another T1 won out. I gave a lot of thought to a WBX, and even bought a couple of core engines and did some investigation with them, but in the end decided I couldn't take a cutter to the car to install the required cooling. My car has a lot of sentimental value, and is just too nice to cut IMO. As for a type 4, the costs ended up keeping me away, especially since I still have a lot of T1 stuff in my collection. This effected the WBX decision too.
As for the new build, not all the details have been worked out yet. I did order some CB IDF fuel injected intakes, so I could either continue with the GSXR ITB's, or put some plenums on top of them for a better single TB setup. As for improved cooling, I decided I'd give a DTM a try, along with some other potential internal engine and hardware changes. Going with DTM stipulated going back to a mag case, but I have two that I can work from. The DTM was admittedly a little pricey, but I figured if it works its money well spent, and if not it would be easy to part with down the road if it didn't work out.
I'll likely post up a new build thread since it will be ground up again, but for now I'm just collecting the parts.
