possible intake leaks
dstar
Post by dstar »
raygreenwood wrote:Five hours of after work labor?!!!....whose "oysters" are YOU shuckin!? :shock: :lol: 8) Ray
Don
platform115
Post by platform115 »
maybe that's to get my oysters shucked :P
raygreenwood
Post by raygreenwood »
The really sad part.... :cry: ...is that the first thing I thought of was a poor employee...being on the wrong end of the "pink stick"......like it didn't occour to me that you could be on the right end of it. You can tell what kind of year I have had. More power to ya if you have to stay after class for "advanced studies".... :lol: Ray
platform115
Man! That's rough, well hopefulyy this next year will have better luck for ya!
it's only a few weeks away you know
dstar
Post by dstar »
platform115 wrote:Man! That's rough, well hopefulyy this next year will have better luck for ya!
Ray can't complain, I'm *sure* he had a Philipinno *Hochie Mama*
giving him some *time* will he was there on *business*....
:twisted:
I know from experience that *I* wouldn't be too worried about him....
as long as he got his SHOTS when he got back in the STATES!
8)
Don
platform115
HAHAHA..
I have so much to say about this (since everyone I work around in Navy, or ex Navy), but I'll be quiet :P
hey Dstar, I left a message or two at that phone number, I don't know if you got it, or if it was even the right number, there was a woman saying to leave a message....
I got the carb a few days ago though.. so I'm ready to discuss the pre-install issues. I'll PM you my phone number, and you can call me whenever it's convenient if you want.
dstar
Post by dstar »
platform115 wrote:HAHAHA..........
Cool, I'll call ya tonight.
I PM'd ya back.
Don
raygreenwood
I'll stay silent at this point....but it is amazing what 1000 pesos (about $20) will buy in the PI . 8) Ray
platform115
Dstar, you have a PM.
platform115
well, this morning was the first time I've had that was daylight where I could work on anything... but now I have to go to work.. :(
That carb is leaking gas really bad though...
bad enough to puddle under my bus...
Dstar... what was the name of the part that you said was leaking... not the plug.. the other part...
is this something I can buy seperately?? I need to fix that before I troubleshoot anymore...
It's getting gas, has good spark, and good compression, but it will not start. Just leak gas.
Even if I put the mixture screw in all the way, and back off the idle... it still gets nothing..
I don't understand... how could it work just fine on your bus, but then not work, leak gas, and need some serious adjustment to run on mine???
I have all the other elements in working order....I'm SO confused man! :shock:
dstar
Post by dstar »
platform115 wrote:well, this morning was the first time I've had that was daylight where I could work on anything... but now I have to go to work.. :(
OK, where is the leak from? You HAVE the book, YOU tell me what part
it is coming from. YOu sure it isn't leaking from a line?
A PUDDLE of gas scares me BAD!
:oops:
platform115 wrote: I don't understand... how could it work just fine on your bus, but then not work, leak gas, and need some serious adjustment to run on mine???
One size doesn't fit all and a 1/4 turn twist isn't all that serious of an
adjustment. I set the secondary high so it would be easier for you to
adjust while it was still installed....
And, it IS possible that the box got banged around and the float is stuck open.
That is the only thing I can think of right now, especially since you said the aluminum plug over the fuel filter inlet was leaking also....
:shock:
I've NEVER seen those leak! A ball peen hamer will seat it tho.
:lol:
Damn UPS sucks!
You said it has leaked a puddle, does it leak just sitting there?
What is your fuel pressure?
We can get ya running, but you are the eyes and you are gonna have
to tell ME what is up.
Don
platform115
Yeah sorry, I'm not trying to be a lazy ass about this :lol: , I've just been in a crazy hurry...
I just got home from work and I'll check the book before I crash, but the stop screw for the second barrel is where the gas is coming from.
it's a pretty steady drip when the pump is on, which is running at 3.5psi
no SH*T! me too! :lol: but it's okay, I'm being carefull.
Yeah, I did think of that, and knocked on the carb a little with a rubber mallet, to no avail...
Well, I thought it didn't leak just sitting there, but when I got home a few mins ago, there was a good half pint of gas on the ground..
It's not still leaking I don't believe. There is no fuel being pumped and the gas on the edge of the puddle had already almost evaporated..
I checked underneath, and one of my exhaust nuts was a little loose and gas obviously had dripped out of the manifold... (then I torqued the nut)
It's also having trouble turning over, so I may need to pop the spark plugs out and see about gas in the cylinders... what you think?
won't start at all...
Yeah, like I said I wasn't trying to just be a lazy ass, I just got a lot going on...
Just finished my finals, and mostly, at work builds(of pc's) are piling up pretty fast for christmas and I've been having to work my ass off...
but hey! there's job security so whose bitchin'?
sorry for the long post.
dstar
Post by dstar »
No sweat Dude! It's a crazy time of year.
:lol:
I guess the best thing to do now is to take it apart and unstick the
float by hand. All the indications are, that the float is stuck.
Can you use the other carb until you can get time to do this?
Time (and daylight!) always hampers projects for us "Po' Folks" without
a garage to work in.
Check your oil and see if the oil level has risen. Another indication that
the float is stuck and the gas is being gravity fed to the carb and filling
up the crankcase with gas.
Another not so good thang!
I'll be glad to help ya over the phone after work if you have the time
to sit down and take ths carb apart.
BTW, good luck on the finals! We'll keep our fingers and toes crossed!
:lol:
Don
platform115
Yeah, I'll try that, but man you are dead on with that last one...
I'm living with someone temporarily (everyone was kicked out of my last home unexpectedly because the landlord was pretty wacko...)
But next piece of property I settle my stuff on I'm buying. AND IT'S GONNA HAVE A GARAGE!! :lol:
How does that work?? it just leaks past the rings???
THANKS! I have my last one today
dstar
Post by dstar »
platform115 wrote: Yeah, I'll try that, but man you are dead on with that last one...
Ah, college life...... :lol:
platform115 wrote: How does that work?? it just leaks past the rings???
Yep! Fills the cyls, then runs into the crankcase.
It's the reason for not turning over very well and not RUNNING also!
I'm not gonna leave ya *in the cold*! I'll help as soon as you get the opportunity to work on it!
The last thing I want to hear, is that it does not run....
Don
