Now we are getting somewhere...
Currently, at half lift, the rocker tip contacts the lash cap dead center (top to bottom), and if I draw a line perpendicular to the valve stem at the point of contact (lash cap to rocker tip), it passes right through the center of the rocker shaft. This looks good to me.
With this in mind, when I look at the adjuster screw, it is about 3 degrees off parallel with the pushrod, such that if I shimmed the blocks out a little, it would become parallel.
Should I leave it like this, or shoot for the adjuster screw being parallel by shimming out the shaft blocks, or should I compromise, taking a little angle at the perpendicular measurement and at the adjuster shaft?
