I had an interesting problem similar to this . I wanted to validate/calibrate my headtemp gauges ( I have 2 type 4 vehicles). Using the boiling water method I found the two vdo guages to have @ 50 degree discrepancy between each other and both to be a bit high. On the way back to the car I dropped one of the gauges. It then read 150 degrees when totaly disconnected! . I took a jewlers screwdriver and pried the chrome ring that holds the glass in enough to lossen the bezel and then rotated the gauge back so the pointer was at zero when unconnected. I then retested the two gauges and they both read almost the same!
You might check to see if the gauge will read zero when totaly diconnected .
If your gauge is useless consider one of thesehttp://www.dakotadigital.com/Detail.cfm ... roduct.htm
Bill
Jake you were right about the 12 and 28 timing!!
Nice, those Dakotadigitals appear to use TCs...
Now if they would sell them with the 10 ft pigtails we need...
- shambly
Jake,MASSIVE TYPE IV wrote:Yep... Now Mark above 4500 RPM pull some more timing out of your system, try 3-4 degrees and see how the top end cleans up and revs faster. Advance is needed less and less as piston speed increases
The Kit Carlson system in, my 912 responded nicely when I did this.
This is an old thread but you'll know why I came across it...
Anyhow, I have the Hyfire VI CDi box in my speedster which has an RPM controlled output switch and a ignition retard input switch. Hook the two together with a 10Kohm resistor (to 12v) and you can have, say, 3 degrees of ignition retard switched in above, say, 4500 rpm.
Would this be too unsubtle, or upset the AFR with carbs?
Simon
If it worked, it would be a nice feature.shambly wrote:Jake,MASSIVE TYPE IV wrote:Yep... Now Mark above 4500 RPM pull some more timing out of your system, try 3-4 degrees and see how the top end cleans up and revs faster. Advance is needed less and less as piston speed increases
Simon
You will simply have to try it.
