The Ragtop Express
TPB_Karl
Re: The Ragtop Express
Post by TPB_Karl »
I have also fitted the rear replacement panels and corrected the fold in the bottom of the piece as this is only folded over once.
Since the bumper mount is shaped like a cone with a closed bottom, I drilled a drain hole in the front. Because I will lower the front, but not the rear.
I previously made a piece that I finally took courage and welded on. With the TIG! I dipped the tungsten probably 12 times and blew 3 holes that I had to fill... Things you learn from, and next time it will hopefully go better!
The next piece to fit in will be the lower part of the inner fender. This needs a lot of modification... But we will do that next weekend!
TPB_Karl
Post by TPB_Karl »
This weekend, I made the final modifications to the panel that will sit behind the passenger door and tacked the outer skin together.
But first, I cut out and repaired the floor lip behind/under the back seat and welded the bottom of the lower corner so I wouldn't fill the heater channel with water.
I removed most of the paint from the outer skin, applied primer on the inside, and carefully started welding it in place with the TIG.
So far, it looks good. It doesn't seem to have warped. Now it's time to continue with the inner fender before fully welding the outer skin.
The inner fender, however, requires quite a bit of work... First up was this weird little pressing.
Since the panel is designed for newer cars with a Z-bar, I have to close up the opening to make it more like the original. This was patched up, and the panel was trimmed to fit the existing inner fender.
However, I wasn't happy with the sharp rear corner of the opening at the shock mount, so I rounded it off a bit.
Then I realized that the bottom line of the bottom of the body didn't line up at all, so I redid the entire rear half and also part of the opening near the shock mount.
Now it's welded and ground down. This piece took way too long!
The next step will be the reinforcement piece that goes on top of the inner fender. and the mount for to the shock tower.
TPB_Karl
Post by TPB_Karl »
This week, I got the outer skin behind the passenger door fully welded.
After grinding it down, it looks pretty good. I had to straighten it with a hammer and dolly a little, and will probably need to do some more hammering before it gets filled and painted.
The next step is to make the reinforcement that sits inside the inner fender. I made a template for it on paper.
Then I transferred it to sheet metal. I cut it out with a couple of centimeters of margin around the edges that I could trim it down once I was happy with the shape of the piece.
After a lot of shaping and bending, I got the piece fitting fairly decent.
The opening around the shock mount is made so that I have space to remove the damper and possibly fit a kafer cup bar.
Trimmed and drilled, it was ready to be welded onto the car.
I also started making a bracket in 2mm sheet metal. Whether I'll use 2mm or 1.5mm remains to be seen.
Hopefully, I’ll be able to finish this side during the week before I leave for work in germany for 1.5 weeks. Cheers!
TPB_Karl
Post by TPB_Karl »
Early update this week!
I decided to use the bracket out of 2mm sheet metal instead of 1.5mm. After all, it’s supposed to be a looker!
The brackets have double layers of sheet metal at the bottom, and here I used 1.5mm as in the original. However, I made them slightly longer than they originally were.
Then, it was just a matter of massaging them into place and welding them on.
Next, it was time for the rear end pieces… But first, I wanted to free the apron while I still had plenty of space to work with the cutting tools.
Once that was free, I could start welding since I had already cut the piece to fit.
Now, almost the entire passenger side of the car is repaired. There are still some small holes in the floor/sill that needed patching, but I didn’t spend much time on those since the entire heater channels and floor pans will be replaced eventually.
With that, I’m taking the rest of the weekend off and will be back in the garage in about two weeks!
TPB_Karl
Post by TPB_Karl »
But before heading home, I just couldn’t resist…
While cleaning up, I found a piece of sheet metal with paint in decent condition. I just had to try cleaning and polishing it to see what the car’s finish will look like!
I was a bit too aggressive with the wet sanding and rubbing before polish, so the primer burned through. I’ll have to be more careful when polishing the body.
But that’s a long way off… Take care!
TPB_Karl
Post by TPB_Karl »
Time to continue the rust repair. The heater channel was really rotten.. Since i'm planning to one day replace these or at least repair them properly with the body off of the pan, Im not being to picky on this repair..
You've seen this process before, so im just posting the pictures on this side.
I've started to prepare the outer skin behind the drivers door, but there is still work to do..
A lot of work remains until this side is done. But i feel like im off to a good start. Take care!
TPB_Karl
Post by TPB_Karl »
Before welding the outer skin behind the driver's door, I took the opportunity to clean it up and apply rust protection primer.
After quite a bit of massaging, I was satisfied with the fit of the outer skin. So, I sanded it down to bare metal and applied weld-through primer on the inside.
Then, it was time to start tack welding with the TIG.
Once sanded, it looked pretty decent.
The next step is to continue with the inner fender.
It should, of course, match the passenger side. However, this was all I had time for this weekend.
TPB_Karl
Post by TPB_Karl »
The inner panel fit about as expected, so I'm trying to replace as little as possible.
The rear floor section edge needed replacing, just like on the passenger side.
Then trim the piece to fit, and weld it in place. I struggled with the TIG for some reason, but in the end, it was welded.
Work continues next week. Have a great weekend!
Beautiful work as always!
TPB_Karl
Post by TPB_Karl »
Piledriver wrote: ↑Fri Mar 28, 2025 1:01 am Beautiful work as always!
Thank you! Hopefully I'll be able to bring some more interesting updates as soon as the rust repair is done.
Next week I'll have som rubber on the BRMs. 8)
TPB_Karl
Post by TPB_Karl »
A small mid-week update showing something other than rust repairs..
The BRMs are in rubber. Decided on Michelin all around. XWX 205/70-15 rear and XZX 145-R15 front.
Howerver they were a bit brown and still had grease from mounting so i used some rubber cleaner and "satin" tire dressing. They look alot better now! The wheels needs a coating to protect them from dirt aswell.
(After / Before)
TPB_Karl
Post by TPB_Karl »
Early update this week again. I’ve finished the reinforcement plate and the bracket.
Then there were two holes in the fender mounting that needed fixing.
I pulled out the dent and welded up the hole where someone had used a drywall screw to hold the fender in place...
TPB_Karl
Post by TPB_Karl »
Next bit was another section of the fender mount and part of the inner fender.
Taped off the area and marked out where the bends would go. After some beading, flanging, stretching and English wheeling, the sheet metal started to take shape.
Trimmed the sheet and cut out the happiest hole I’ve ever seen.
After slow and methodical TIG welding, since I can’t reach the outer welds from the inside for hammering.
If I haven’t missed anything, all that’s left to fix for rust is the firewall tip and the middle panel! :yahhoo:
We’ll take care of those parts next week. Take care!
Again, beautiful work!
You should consider naming her ""Patches" ;-)
SCOTTRODS
Post by SCOTTRODS »
Like eating an elephant... One bite at a Time. Great progress.
