Not much has happened since last weekend. We've had nothing but rain in my little part of England (and the rest of it) which is amusing given that most of us are in drought conditions, with a hosepipe ban running in a lot of areas.
Went out for a little drive last weekend... shouldn't have, as I can't use any boost yet... so really just a run out in a low compression 1.9, hardly exciting. I played with the start fuel map as per Wallys instructions and she starts great now, both hot and cold, I'll post the map at some point.
There's a big hickup at low revs that will get sorted at some point, but other than that, nice and smooth. Driving without letting any boost build isn't fun! A bit like jumping off the missus just at that special moment... if you know what I mean! But I needed to be able to drive it just for a mile or two, before pulling it all to bits again.
Here's how it looked, back from the rolling road after the guys did all the initial plumbing and wiring setup.
Need to do a bit of work on tidying the wiring and plumbing. I don't love my turbo to throttlebody pipe, but it'll do for now until I get one made up and I'm unhappy with the routing of a lot of the sensor wires too. I need to learn more about the mexican setup and what should be blocked off / replaced or upgraded, but it is running, so I'll just be finishing this stage first.
Comments are invited on whats happening with the plumbing on the base of the manifold! Should I be running a hotter plug where that air valve thingy should be?
OK so, weather permitting this weekend... Engine out and heads off to be sorted. Whilst the engines out I've got a pair of rhino mounts to fit and I've got hold of 'half' a strap kit, the front end, which I'm hopeing will help to stop the (standard!) gearbox falling to bits before I get any miles on it. Ideally I'd like to triangulate the frame horns with a truss kit and stick a mid mount on the box... it's frustraiting that I haven't got the skills to fabricate the stuff myself, especially as I'm on a very tight budget at the moment after spending on the initial set up.
I'm also going to get a boss for a wideband AFR welded into the exhaust whilst it's in bits (about time I hear you cry!)
