Hi again
The engine has run over 2.000 km or so. I have more information now from it.
It runs "fine" ... but I think it can be improved.
The response is not equal all conditions. Is a difficult to explain but I would try:
I would say it seems "coolder" first couple of minutes when started at the morning. You must wait a bit more now than before. Just passed one minute or so, it revs when you push the foot.
Next minutes -the temp still is under mid scale-, the engine revs clearly when you press the accelerator. I am talking about low gears, street use.
When the cruise temp is reached - in my gauge more or less the mid range-, you get better response pressing the accelerator slowly than faster. Is it rich fuel mixture?.
When cruising -at 3000 rpm or so- the response is a bit slowly (5ª gear at 110 km/h). But the wors part is when the road climbs up. Only if you are over 3500-4000 rpmk, the van can keep the speed. Under those rpm, starts to fall down.
Last feedback information: the van still does a 14,5 l/100km of average.
So I think there are two solutions:
a) Improve richment fuel mixture in all use conditions
b) Remove distributor and fit a real ECU controlled ignitor.
Yes, I am thinking in a MS. I have read about it in forums but still have some doubts (the only thing I really have for suer is that I am going to fit one, sure
I will open a new thread in "Engine Managment" asking for help
