Page 4 of 4
Re: DJet help bucking, stuttering
Posted: Sun Dec 12, 2010 11:20 am
by raygreenwood
Lets adjust what you have first...but you should always be on the lookout for spares. Ray
Posted: Sat Jan 01, 2011 11:22 pm
by rayray1
Piledriver wrote:CHT resistor reads how many ohm cold and also check hot.
(frequently flakey item, perhaps the most likely other than a wiring issue)
Try replacing it with a 5K potentiometer.
Shoot for 28-30 PSI.
WHAT is a cht ?
can you please expand the language for us less techie type 4 folks, who are looking for help too.
thanks much, ray rau. st.pete fl.
Posted: Sun Jan 02, 2011 1:19 am
CHT=cylinder head temperature
EGT=exhaust gas temperature
TPS-Throttle position sensor (Djet doesn't really have one like more recent FI setups, it's more of a throttle motion sensor, could easily be redesigned with a hall sensor...Ray :wink: )
Grapefruit: :lol: The exquisite variable transformer differential barometer DJet used as a MAP sensor.
Developed long before modern piezo sensors existed.
Posted: Sun Jan 02, 2011 9:40 am
by rayray1
Piledriver wrote:CHT=cylinder head temperature
:shock: Thanks very.. much.
Can you respond to the querie i posted on the 'burp' and flat spot my 72 411 has>>? Could it be as simple as temp sensor...? The one that screws into head.? I think-
0r this grapefruit thing..? and where would this darling be hidden.... - rayray1 -
Posted: Sun Jan 02, 2011 11:59 am
by akokarski
Had sometime to pull distributor, distributor drive pinion is at 60* like it supposed to. Also pulled injectors and looked at the seals, they are fine. I need to post a picture of the seals I have. I am not sure if I am supposed to use 2 on each or one.
Also I don't think I am getting much power out of #3 when I pull the plug on this cylinder it doesn't affect idle as much as others. This is a cylinder with lowest compression.
Adjusting TPS seem to make it better, but right now I cannot get it to idle ok at below 1k rpm.
Any how, I've picked up complete engine from 71 auto with wiring harness and all FI parts, but after looking at the terminals and missing exhaust nuts I've decided to rebuild it and bump it to 1776 with new cam, lifters, P&Cs and full flow. Tore it down seems to be looking ok, nothing screams disaster except for mismatched heads and few minor missing parts.
For engine rebuild I'll open a new thread...
Anton
